vvti - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2005, 06:53 PM   #1 (permalink)
southern racer
View JLcamrydave's Photo Gallery
4th Generation vvti
is it psoible to convert a non vvti moter to a vvti kinda like not vtec to vtec or should i just spring for vvti or just not get the vvti to some of u thats a stupid question but i had vvti on my corolla when i had it and i liked it
JLcamrydave is offline   Reply With Quote
Old 10-19-2005, 07:06 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Probably not going to work unless you do some major work. Isnt most of that stuff computer controlled. If so you will need the ECU wiring harness and all. IT would end up being jsut like an engine swap for the most part. Then you also have to have an engine block tht will accept the vvt-i head> so if the engine in your car has never had the option of vvt-i then it will make it even harde.
I am in no way an expert on vvt-i since it was just starting to be used a little bit when I left Toyota. But I would think this would be the case.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 10-19-2005, 09:41 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
engine swap (and everything else required) for the same engine with vvti would be cheaper and easier
terrastrife is offline   Reply With Quote
Old 10-19-2005, 09:52 PM   #4 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
Dumb Question: But what exactly does VVT-I do for the engine. What is the difference between a Toyota engine and a Toyota VVT-I?
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 10-19-2005, 10:03 PM   #5 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
VVT-I gives low end tourqe and gives more hp at high rpm
usualy you have to choose between those 2
like having to choose between a 3S-FE (low end tourqe)
and a 3S-GE (high horsepower) VVT-I gives you both
Zandro is offline   Reply With Quote
Old 10-19-2005, 10:58 PM   #6 (permalink)
southern racer
owens do your resurch u were the one askin stupis stuff u must not know much about cars before making stupid remarks look it up so u want be shamed making a stupid remark "Dumb Question: But what exactly does VVT-I do for the engine."
Old 10-19-2005, 11:03 PM   #7 (permalink)
southern racer
One More Thing Owens How Did U Get 167hp On Your Camry U Must Got A Turbo Or Spry And U Know Alot About Car Audio I Am 22 Never Went To School For Audio Started Workin On Car Audio At The Age Fo 14 And I Got A Car Audio Shop Opening Up
Old 10-19-2005, 11:16 PM   #8 (permalink)
Midship Captain
ModifierMR's Avatar
JL, Please Enough the kinda remarks u are making are Un-nessasary and against TN Rules and polocies.
I think you should Check yourself Newbie. And another thing Stock Gen5 Camrys are 160hp. Sorry but its a fact its not something i made up.
And another thing....I know enough about cars. im no mechanic but i know what an engine does and all the components. So please keep your stupid comments to yourself.
すべての日本への私のお悔やみ。
Old 10-19-2005, 11:18 PM   #9 (permalink)
Midship Captain
ModifierMR's Avatar
On top of that, you wont last long on TN with that additute. Most people on here are Helpfull and not aarogant like you
すべての日本への私のお悔やみ。
Old 10-19-2005, 11:18 PM   #10 (permalink)
View AutoBox's Photo Gallery
VVTL-i =Variable Valve Timing w/ Lift & intelligence
yeah its a nice feature to have if you already got it, if not...motor swap i guess but would it really be worth it? how much estimated hp/torque would you gain?
JLcamrydave-uh use the PM feature if you wanna get someones attention
AutoBox is offline   Reply With Quote
Old 10-19-2005, 11:37 PM   #11 (permalink)
Moving Forward
by the time you do the complete engine swap you could probably have put that money torwards other mods that would maybe get you close to the gains you would have gotten doing the engine swap and maybe have soem money left over. I am sure the vvt-i engines are not cheap since they have not been around very long unless you could find a totalled car withone for very little money.
Only two listed on Ebay right now and they are 2jz for 990.00 and a 1mz for for 1200.00.
Well maybe they woudnt be as expensive as I thought but then you still ahve to have all teh ECU and harness and on and on
Chris
