Fr engine mount install update - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2005, 10:25 PM   #1 (permalink)
View camry300's Photo Gallery
I happen to find the easy way to do the engine mount when I replace my Y pipe. With plastic cover under the radiator removed and Y pipe removed, place a jack under the engine cushioned with a block of wood. Remove the 3 14mm bolts that attached the mount to the engine and the three 14 mm bolts to the fram. THe tip is do not try to unbolt the 17mm bolt.
It is much easier. You might need a lot of extensions and a break bar. Actually the bolts are very easy to remove.
camry300 is offline   Reply With Quote
