NO youdont have to remove the entire door panel. Jsut use a small bladed flat screwdriver on the end towards the back of the car and pus in to relese the clip then pull it up. Once you pull up on teh back of the switch you will need to pull the entire thing towards the bacl of the car because there is a clip that slides under the door handle to hold it in place at the front of the switch. Be careful though because the clip that holds it in is a metal spring and if you do it wrong it will not hol din place very well after you put it back.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
