Penny Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2005, 11:09 AM   #1 (permalink)
View Reppinshadyvill's Photo Gallery
4th Generation Penny Problem
In a nutshell i had too much change in the little storage space in front of the tranny shifter and i managed to get a penny stuck in the secondary 12volt power source. Its stuck in the wide way, face up completely blocking the power source and its jammed all the way at the bottom. My question is if I take out the 12 volt source will I be able to pop the coin out from behind?
Reppinshadyvill is offline   Reply With Quote
Old 10-21-2005, 11:13 AM   #2 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $111850
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
should be able to disassemble the whole socket.
btw, I'd pull the fuse asap ... its connected to the clock and the radio as well. I had a phone charger fall apart in the socket, the fuse didn't snap and it shorted my hu
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 10-21-2005, 11:24 AM   #3 (permalink)
Torque Applicator
Bluesabre's Avatar
View Bluesabre's Photo Gallery
Question No cap?
As I read this I would guess you are missing the cap that covers your 12V source? Once you get your penny out, I'd suggest you get the cap replaced, from a junkyard if possible.
1998 Camry LE
5SFE
If you're not livin' life on the edge, you're taking up too much space. (stolen)
Bluesabre is offline   Reply With Quote
Old 10-21-2005, 11:28 AM   #4 (permalink)
toot toot ahhhh beep beep
View cuttooth's Photo Gallery
u cant get it out?
how about a stick with something like crazy glue on the end?
'02 is300, eShift, LSD
'94 toy pickup, 22re, 5spd, xtra cab
cuttooth is offline   Reply With Quote
Old 10-21-2005, 01:19 PM   #5 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
take apart the bezel, then u can unplus the outlet
and hit it from behind or a screw driver to pop it out, just dont this when its plugged in
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 10-21-2005, 01:28 PM   #6 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
Same thing happened to me on my old car. I couldn' t figure out what kept blowing fuses so unfortunately I took it into the shop. I don't remember how much they charged me, but it was way to much to remove a dime from the cig lighter!
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 10-21-2005, 02:12 PM   #7 (permalink)
Gameroom cash: $304355
Disconnect the battery (or the fuse if you are absolutely certain you know which one it is) and then use a dental pic or something like it to pull it out. I don't believe you will have to disassemble anything else.
Good luck.
Mike
Old 10-21-2005, 09:38 PM   #8 (permalink)
View Gary_602Z's Photo Gallery
Did you try the piece of bubble gum on a stick trick?
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 10-21-2005, 11:24 PM   #9 (permalink)
Whats a Noobian?
sq_camry's Avatar
View sq_camry's Photo Gallery
you can disassemble it, ive done it with the cig lighter, so it should work w/ the aux power
sq_camry is offline   Reply With Quote
Old 10-22-2005, 09:25 AM   #10 (permalink)
NIGHT STALKER
throwback's Avatar
View throwback's Photo Gallery
All you got to do is disassemble it and take the penny out and it should work without a problem. Like they said^^^^^^^^^.
NIGHT STALKER
throwback is offline   Reply With Quote
