difference of the generic n oem sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2005, 03:42 PM   #1 (permalink)
View camry300's Photo Gallery
I just bought the NTK generic O2 sensor .
First the generic is smaller in size and shorter in length when compare to the oem ( Denso)
I happen to install them with the Y pipe removed and I find the following ; the bank one senors expose less of its protective shell openings then the oem which is longer., the bank two sensor's protective shell openings are almost completely buried in the bunk of the sensor- . Luckily the generic sensor is thinner than the oem so exhaust air can still reach the openings of the sensor but might be restricted.
I sahll update later whether the generic sensor will cause any problem especially to bank two.
camry300 is offline   Reply With Quote
Old 10-22-2005, 01:53 PM   #2 (permalink)
Thumbs up
an update for the nTK o2 sensor So far so good>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
