Tokico vs. KYB GR-2 - Toyota Nation Forum : Toyota Car and Truck Forums
ğ Wheel & Tire Center
Old 11-10-2001, 12:38 PM   #1 (permalink)
Ice
View Ice's Photo Gallery
Hey guys,
My rear shock died so i need to replace it. I think i might drop it while at it :smile: I want to get H&R Springs, but how about shocks? Tokico's are $440 and KYB GR-2 are $280. That's a big difference in price. Any suggestions ? These are for my 1995 Camry i4 5S-FE 5Spd. Also, my brakes need to be changed. I need to get new pads and i think my discs are gone too :sad: I was thinking about getting Powerstop Drilled disks. They're $150/pair for front and i don't know what i have on he back ?!?! any suggestions and comments about struts, pads, and disks ?!?! Thanks a lot
Ice is offline   Reply With Quote
Old 11-10-2001, 02:14 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Camry's use struts not shocks.
Both the Tokico and KYB-GR2 struts are good. The Tokico's are a little stiffer though. Its up to you.
I'm not a big fan of cross drilled, slotted, or cross drilled + slotted rotors.
Heres why:
The rotors and pads work by friction. If you start drilling holes and cutting slots into the rotors theres less surface area for friction to be applied. The only part that matters is the part that the pads contact.
The cross drilling and slotting is good for cooling and out gassing of the brake pads but, they suck for stopping power. If you want something that'll increase your stopping power look into big brake upgrades (big vented rotors and multi-piston fixed calipers). Bigger = better. Not drilling holes and cutting slots into s**t.
By the way those Powerstop cross drilled rotors are the same size as the stock rotors.
Drums.
Old 11-11-2001, 06:10 AM   #3 (permalink)
Toyota Lexus Scion Guru
View Flipside909 [SC³]'s Photo Gallery
5S-FE Gen3 WITH ABS has rear discs. If it's non ABS, it's a drum. If you have a big open space next to your windshield washer reservoir and coolant overflow reservoir...you don't have ABS.
ClubLexus Editor/Events Coordinator
GRS191
Flipside909 [SC³] is offline   Reply With Quote
Old 11-11-2001, 05:07 PM   #4 (permalink)
View speedemn's Photo Gallery
You get what you pay for... period. :wink:
I got the Brembo cross drilled rotors and KVR Carbon pads. I give them two thumbs up so far!
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
Old 03-21-2002, 01:13 PM   #5 (permalink)
View dctodd's Photo Gallery
Hey everyone, new to this, hoping someone out there can help me out. I have a 2000 V6 solara and I just got Eibach pro kit and wanted Tokico struts. However the shop could get them in, didn't want to wait so they told me KYB were just as good, however from everything I read doesn't seem so. Can anyone tell me how my car is going to ride with the Eiback 1.6'' drop and KYB GS-2 ?? I don't race or anything just aggressive driver in Chicago. Will it be a better ride then the stock stuff ?? will this combo make it worse ?? Thanks
dctodd is offline   Reply With Quote
Old 03-21-2002, 01:26 PM   #6 (permalink)
View Keyser Soze's Photo Gallery
Check out this link for a Brembo disc group buy. http://www.teamsc3.com/ There's a guy on there selling them for $50 each disc- and you can get 'em drilled, slotted, or both. I had a set of drilled/slotted rotors on the front of my 96 Civic- no other mods- and I noticed that they bit alot harder than the stock rotors. The holes/slots are there to relieve gas pressure that builds up under repeated braking (for more consistent braking w/much less fade), and also lets water escape for better wet weather braking. There's only a minimal loss of braking area- and the benifit outweight the downsides by a large margin (in my opinion). If you get high performance pads rather than stock ones, you'll gain more braking power overall. Plus, they look way cool behind a set of aftermarket wheels. :smile: I say go for it.
Sorry I can't advise on the spring/shock delima- 'cause I just don't know. :smile:
Keyser Soze is offline   Reply With Quote
Old 03-21-2002, 01:51 PM   #7 (permalink)
View F1 Chris's Photo Gallery
Both KYB and Tokicos suck for Gen3's. I've spoken with people who have had these and they all say that the ride is soft, and they were looking to switch to the other strut for more stiffness...haha!
The rears are fine as they are the same for Gen3 and Gen4's, but the fronts are too soft on Gen3's.
F1 Chris is offline   Reply With Quote
Old 03-21-2002, 02:58 PM   #8 (permalink)
View soundlzrd's Photo Gallery
If you want tokico, i can get them for 270. thats for a gen3. all you would have to pay then is shipping. email me at teammc2@columbus.rr.com, and ill get you the number
soundlzrd is offline   Reply With Quote
Old 03-21-2002, 04:15 PM   #9 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $111850
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Watchu talkin bout Willis!?!
I love my Tokicos.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 03-21-2002, 07:30 PM   #10 (permalink)
getn groceries in style
jwa276's Avatar
View jwa276's Photo Gallery
hey guys, just found an online store that can get them to you shipped for 270-
http://www.coximport.com
hope this helps, ill proly be buyin these soon, cuz my stock ones sure arent gonna last!
jon
'92 Camry SE V6 5spd
jwa276 is offline   Reply With Quote
Old 03-21-2002, 07:39 PM   #11 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700165
iTrader Score: 6 reviews
View EKam's Photo Gallery
Tokico are best in terms of performance/comfort balance since the roads in Toronto are not necessarily the best ones out there.
I know you have TRD struts but I would only put in those if I have a track car.
H&R + Tokico + rear swaybar + STB don't disappoint. :smile:
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 03-22-2002, 12:50 AM   #12 (permalink)
View WeApOnX's Photo Gallery
dude if u want the best ride get the trd struts lol but i dont think that u want to spend a lot of money. i rather get tokico
......I Drive A 2000 Black TRD Solara.......
żżżżżżBut Hey SHIT HAPPENS!żżżżżż
COME CHECK OUT MY CAR
WeApOnX is offline   Reply With Quote
Old 03-22-2002, 11:42 AM   #13 (permalink)
Define best ride? If best ride means comfort...TRD/Bilsteins are not the one since they are very harsh compared to the Tokicos.
GRS191
Old 03-22-2002, 07:41 PM   #14 (permalink)
My TRD's are very stiff...BTW I'm selling them for $300. I got myself some KYB's. I've been able to examine both KYB and Tokico's for weeks and they are practically identical for compression and rebound.
Old 03-22-2002, 11:45 PM   #15 (permalink)
View 92CamryV6's Photo Gallery
Does anyone know how the Koni's ride???
92CamryV6 is offline   Reply With Quote
Any opinions on KYB or Sach struts? tmanana Camry & Solara Lounge 4 07-02-2002 12:36 PM
TRD struts vs Tokico Tubbyc Camry & Solara Lounge 22 05-19-2002 02:19 AM
ROLL CALL: Possible Tokico Illuminas (Adjustable) Flipside909 [SC³] Camry & Solara Lounge 22 05-13-2002 03:11 PM
Tokico strut + Eibach / H&R Tubbyc Camry & Solara Lounge 9 05-06-2002 12:16 PM
anyone use Tokico Blue.... MCV20 Camry & Solara Lounge 13 05-06-2002 08:07 AM
