Power Equation need help
ok so i got a book called Designing, Testing, and Installing turbochargers and in it it has an equation to give equal to power. the equation is Pressure x length of stroke x area of bore x # of cylinders x rpm/2(2 is related to the four strokes because only half of the strokes is it pushing down) the problem is 1. i cant find the bore area and 2. my equation is comin out in like hundreds of thousands. i think the measurements come out in lbin^3/sec
which should be in lbft^3/sec. if i want to push 300hp then i would need 9.5(length of stroke in inches i guess) x Area of bore? x 4(4500)/2 x pressure(lbs/s) = 300
I love my camry even tho its slow as hell
1996 Camry le 5sfe
tokico struts, whitline sway bar, ractive strut bar, weapon r intake, alpine cda9855(  it was a 9821), idq 15, d5 300, d3 400, (seas 7" woofers, lpg tweets), and prolly the only cam with a cb radio
