Oil Level when starting car - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2005, 12:12 PM   #1 (permalink)
Registered User
View qprint's Photo Gallery
When I park overnight at my friends driveway, I worry about starting the car while the car sits on a 35 degree slanted driveway. I'm not sure if the engine oil pump is picking up the oil properly while warming up the car. I can park it downhill [backup to exit the driveway] or uphill[front towards the street]. Do you think its safe and if so, which direction should it be? Front end higher than rear end ?
qprint is offline   Reply With Quote
Old 10-26-2005, 12:21 PM   #2 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
Todays engines are more advanced than what you give them credit for. It doesn't matter if how you park. Your comment leads me to believe you think all the oil drains back to the catch pan..and waits for you to re-start the car...No necessarily true. If i were to park at an inclination, i would back in (ie. keep front side lower than the rear).
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 10-26-2005, 12:32 PM   #3 (permalink)
Registered User
Is the oil pump pickup located towards the front or rear ?
Old 10-26-2005, 12:33 PM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
As long as your oil level is correct you should not have nay problems. The pickup is fairly low inthe oil pan and pretty much centered. SO with the correct amount of oil in it the pickup will be below the oil level at any given time. Like jhbhatia said engines are designed with most of these type scenarios in mind. WHen you start the car as long as the oil light does not stay on then you should not have any problems.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 10-27-2005, 12:07 PM   #5 (permalink)
Registered User
Then, your answers would be to keep front side lower. Correct ?
Old 10-27-2005, 04:03 PM   #6 (permalink)
View Gary_602Z's Photo Gallery
Or find a new friend!
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 10-27-2005, 04:32 PM   #7 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
LOL. It makes no difference.
The pickup is low enough that on almost any incline, the pickup will still work...unless your at a 90 degree/upside down...:P
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
