weird electrical problem in camry...please help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2005, 02:02 PM   #1 (permalink)
Formula One Fanatic
andyman61's Avatar
View andyman61's Photo Gallery
Question weird electrical problem in camry...please help!
i was driving the other night when all of a sudden my headlights, dash, and stereo all go dead. about 3 or 4 seconds later, they all come back on. 15-20 seconds later, just the stereo goes out. so i drive back to the dorms, with no other problems. i go to take it over to the local mechanic today, and as i'm going over there, the stereo flickers off and on a couple times.
he couldn't find anything obviously wrong with it. checked the battery, alternator, fuses, and relays. nothing.
i'm at a loss. electrical is definately not my strong point on cars. the only thing i can figure is a bad connection somewhere, possibly the ground wire. anyone know exactly where the ground wire goes on the 5s-fe? i poked around under there for a little bit but couldn't find anything out.
thanks for any help!
Metal to burn, sparks to fly...
1992 Toyota Camry 5 Speed - 5S-FE....totally stock
andyman61 is offline   Reply With Quote
Old 10-26-2005, 04:56 PM   #2 (permalink)
View karazy's Photo Gallery
Each system has their own ground, so that is probably not the problem. If none of the fuses are blowing, it is more likely an open cct than a short. The one thing that is common with these systems is the ignition switch. This would be a good place to start looking for loose wires and signs of arcing.
karazy is offline   Reply With Quote
Old 10-26-2005, 05:56 PM   #3 (permalink)
Formula One Fanatic
andyman61's Avatar
what does cct stand for? and where specifically should i start looking for loose wires? thanks!
Old 10-26-2005, 07:02 PM   #4 (permalink)
Gameroom cash: $304355
cct means circuit.
I think karazy is correct with the igniton switch. You can try to test this by starting the car and jiggling the key a bit in the switch. See if you can duplicate the problem.
Mike
