Suspension check list:
You should check and replace the following for improved handling, ride, tire wear and safety, not to mention possibly better gas milage:
Struts all four corners
Front control arm bushings (if your car squeaks in the front when stopping or accelerating these are the most likly culprit)
Ball Joints
Tie rod ends
Anytime you replace anything in your front suspension it is best to have the alignment checked. If you are just replacing the struts in the rear it shouldn't be neccesary.
Also if any of your control arm bushings, ball joints or tie rod ends are bad then you car will not maintain proper alignment while driving. Most tire/alignment shops will check these items for you for free and tell you what needs to be replaced.
I just replaced almost the entire suspension in my $200 Camry SW
Thanks to ImageShack for
Free Image Hosting
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
