dash lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2005, 03:09 AM   #1 (permalink)
View mendozer's Photo Gallery
3rd Generation dash lights
hey. i know the general routine of chaning out the lights in your gauges and HVAC console, but for the specifics:
1) for the gauges, can my LED 194 slip right into the casing?
2) for HVAC, the bulbs are right behind the knobs right? just pull em off and replace?
thanks in advance
NOTE: im no noob so please dont flame. also, no thread-hackers. dont come on and ask irrelevant questions for your car, that's what the "new topic" button is for.
mendozer is offline   Reply With Quote
Old 10-28-2005, 03:21 AM   #2 (permalink)
View Admiral93's Photo Gallery
1) yes except one which will fit a 74 bulb (i had to modify it)
2) I believe they are b/t knobs and behind recirculate switch, keep in mind led 74 bulbs are often very directional and tend to leave bright and dark areas in the HVAC. Happend to me when I turned it red, and the led 74s I got didn't go all the way in, I taped them in to the holes from the socket.
Hope this helps!
Brian
93 LE V6, big plans. . . no money (isn't college great?)
Admiral93 is offline   Reply With Quote
Old 10-29-2005, 02:35 AM   #3 (permalink)
why would 3 gauges run off a 194 and one a 74?
also, could i put reflective metallic crap around the bulb to reflect light all around the HVAC?
Old 10-29-2005, 03:37 AM   #4 (permalink)
I dont know why, just is. ask toyota
I dont see that working super well, but you are more than welcome to give it a shot. Let me know how it comes out.
Brian
Old 10-29-2005, 08:41 AM   #5 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
View terrynham's Photo Gallery
ive done this using LEDs in my old Gen3.
http://www.geocities.com/terrynham/94camry.html
the 194 LEDs will fit just fine , the Gen3 uses 4 x 194 bulbs and 1 x 74 bulb.
as for the 74 bulb in the gauge, get a 74 Bulb Holder (just like your other 74 warning lights in the gauges) and a 74 LED Bulb and it will fit:
i also put reflective stuff inside the gauges, a/c controls and shifter light and it really makes the light output brighter
so if you can strategically put the foil around, it is well worth the effort
the problem with the HVAC controls, is that you need to literally take apart the panel to place the foil in...
there should be a clear plastic light dispersal piece in there somewhere, when you get that out you put foil on the back of that
i had the same problem with having dark spots, but this foil thing really helped with it, well it didnt fix it completely, but it is better than before anyway
~ Terry
terrynham is offline   Reply With Quote
Old 10-29-2005, 09:34 AM   #6 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
I did this to my gen 4:
http://www.toyotanation.com/forum/t100888.html
http://www.toyotanation.com/forum/t102960.html
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 10-30-2005, 01:56 AM   #7 (permalink)
what kind of LEDs are those? i fricken bought the 194s and 74s already lol. also, to the other guy, you used just foil?
Old 10-30-2005, 02:15 AM   #8 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
yep just use foil
or you can use something else more reflective if you have it.
~ Terry
Old 10-30-2005, 02:52 AM   #9 (permalink)
where is the 74 in the gauge? cuz theres 4 gauges (thats 4 194s)
Old 10-30-2005, 03:05 AM   #10 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
(sorry, to whoever this pic belongs to, i didnt have a pic of a LHD Camry Gauge to draw on)
the red circles represent the bulb locations, the 4 194 bulbs and the 74 respectively.
the Temp and Fuel Guages dont have bulbs behind them, the light is emitted from the sides of the other 2 gauges to illuminate those if you look carefully.
~ Terry
Old 10-30-2005, 07:38 AM   #11 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Within the last week I've completely disassembeld my Climate control and replaced the 4 194's in the cluster, and working on the 74. IM me and I'll let you know about it.
5 Lug Corolla WHAT?
