My first guess would also be the slide pin(s) are sticking. If you can really move them that easily, then the next thing to check would be to see if the piston itself has siezed in the caliper and therefore is not retracking, causing the pad on that side to always be in contact with the rotor. Was the pad that was completely worn down on the piston side? There may also be some excessive heat if this is the case. After driving a while, put you hand on the wheel on that side (don't touch the rotor itself as that is extremely hot!) and feel the heat. Then for a comparison, feel the wheel on the other side. Is there a noticeable different in the heat? This type of problem and the heat created might also cause the car to pull to the opposite side when braking. If the caliper piston is seized, you need to rebuild the caliper if possible, or purchase and install a rebuilt caliper.
Mike
