Autotrans help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2005, 10:58 PM   #1 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
3rd Generation Autotrans help!
Hi, owned a '92 and '93 Camry- both destroyed by semi's. Now own '91 truck, '92 Camry and '01 Camry. '92 is 2.2L autotrans 235K and has been running great. Fluid has been changed about every 50K. No problems beyond 'normal' slow to upshift to OD when cold. After several normal city miles followed by 10 miles hi-way - I exited to a stop. On takeoff it barely moved until speed reached around 30mph. Obviously stuck in 3rd ar OD. Same at next 2 stops. After hours parked it shifted OK but I didn't drive it far. Anyone know what to look for? Stuck solenoid, speed sensor, something causing wrong signal to/from ECM or is trans and/or torque converter about gone? Appreciate any advice. Thanks.
Dave's is offline   Reply With Quote
Old 11-03-2005, 10:16 PM   #2 (permalink)
Dave's
Update: I haven't been driving the car much and work mids so- anyway, tried driving it a bit and it was fine for two stops and then got erratic. I'm slowly learning tho. Pulled the codes and it says the #1 solenoid is the problem. Just pulled the pan and found it. Will be testing it tomorrow. I'll let you know in case anyone cares.
Old 11-04-2005, 12:01 AM   #3 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
yeah if i would have seen this sooner, i would have said, one of the solenoids is bad... lol...
you can maybe grab one out of a junkyard car for cheap.. or pick up a used auto tranny for like 150 bucks, they are SOOOO common too.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 11-08-2005, 10:57 AM   #4 (permalink)
Dave's
on the road again...
Solenoid from friend's salvage, new gasket which came with a screen/filter (I'm a little concerned- it's for my tranny but the screen area is about 1/4 the size of the old one), nearly 5 quarts of Dexron III and everything's good so far.
Old 11-08-2005, 07:41 PM   #5 (permalink)
R/C Junkie
View Smiff 24's Photo Gallery
Hey Dave
I have a 94 camry auto, and have similar problem
I pulled the code and mine says no 2 shift solonid.
once you drop the pan and the screen were the solonids there ?
how do you know which is which ?
94 camry le 4 cyl.
Smiff 24 is offline   Reply With Quote
Old 11-08-2005, 09:29 PM   #6 (permalink)
View Gary_602Z's Photo Gallery
The best manual available for tranny work is an ATSG manual! Covers everything you need to know on trannys. I believe that they have them for Toyotas. Check at NAPA that is where I get mine. They are also available online.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 11-08-2005, 11:14 PM   #7 (permalink)
Dave's
smiff
Once the pan is dropped the solenoids were obvious. They were on the driver's side one toward the front and one toward the back. One has a white wire and the other is black. According to w**.rockauto.c** the #2 is the black wire (part# TCS15) so the #1 is the white wire (part# TCS14). Mine is a A140E tranny. After removing mounting bolts just grasp and wiggle out. There's an O-ring sealing it in place. Only physical difference I could see was the bracket welded to the solenoid. Actually think both solenoids were OK after bench testing and blowing out with 65psi air but I had one from my friend so I changed it. Calmped the body to the neg terminal of a spare batt and then jumpered the connector and touched jumper to positive. Pressing air nozzle to center and then touching jumper causes air to blow thru passages. With no power the air should not pass. Hopefully this will make perfect sense when you've got one out. I was confused until I did it. Good luck.
Old 11-09-2005, 06:27 PM   #8 (permalink)
R/C Junkie
Dave thanks for the good info
sounds like its not too bad,whenever i tare into something i havent done
before,,parts usually fly everywhere !!!
Ill go get the manual Garys talkin about, and do it.
thanks for yalls info
94 camry le 4 cyl.
Old 11-09-2005, 06:38 PM   #9 (permalink)
Here is one online source I am sure there are many others.
http://www.txchange.com/atsg.htm
Gary
