Key doesn't go in ignition - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2005, 05:40 PM   #1 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The key in my Camry won't go in the ignition all the way. It goes about half way in sometimes and then won't let me push it any more. It takes a few tries of pulling it out and inserting it to get the key all the way in so I can turn it.
How to fix this? Do I need to replace the key cylinder?
2007 Camry 2.4L 5M
Old 10-31-2005, 05:51 PM   #2 (permalink)
1993 Camry XLE
HoboJoe's Avatar
View HoboJoe's Photo Gallery
I had this happen on my 73 mark IV, I had to replace the key cylinder thingy. Didn't cost much, about 50 dollars.
Though on mine the key went all the way in and wouldn't turn.
edit: I'm going to assume the pins or whatever inside the cylinder are worn, that's what was wrong with mine. Fix it before it's too late.
HoboJoe is offline   Reply With Quote
Old 10-31-2005, 05:58 PM   #3 (permalink)
Cam I get a new one from Napa or do I need to go to the dealer?
2007 Camry 2.4L 5M
Old 10-31-2005, 06:05 PM   #4 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Spray a lubricant in it, JUST A LITTLE. Don't use WD-40 as it may harm it. I think what you use is Graphite. Forgot as it's been a while since i did it last. But I had the same problem with my ignition. Fixed it and never happened again.
5 Lug Corolla WHAT?
Old 10-31-2005, 06:26 PM   #5 (permalink)
TACO FTW
Location: Norton Shores, MI / Houghton, Michigan (MTU) FTMFW
View 92_Gen3_5SFE_LE's Photo Gallery
Just take a pencil and draw all over your key then slide it in and out a few times. This should help quite a bit. I t definitly made a difference in my '92.
92_Gen3_5SFE_LE is offline   Reply With Quote
Old 10-31-2005, 07:23 PM   #6 (permalink)
I got something called Lock-Ease - graphite lock spray from Napa. Problem is fixed.
Thanks!
2007 Camry 2.4L 5M
Old 10-31-2005, 07:31 PM   #7 (permalink)
Originally Posted by touringcamry
I got something called Lock-Ease - graphic lock spray from Napa. Problem is fixed.
Thanks!
I was right for once!!!!!!!
5 Lug Corolla WHAT?
