My Squeeky Drum - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2005, 10:31 PM   #1 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
Gen5 My Squeeky Drum
Well for a few months now i have been hearing a slight squeek from the outside when i take my foot completley off the brake. Sometimes 2 rapid squeeks.
Its the same kinda sound a swing with metal chains sounds like when it squeeks.
Now i posted this before thinking it was the front brakes. Everyone told me to get new ones, But i checked the front brakes and there is enough pad there to last me till my oil change in about 2 weeks even for a couple more months.
I located the squeek to be coming from the rear of the car. This sound also accours when i pull and release the E-Brake. Scince the E-Brake locks the rear brakes im thinking that maybe the Drum brakes are bad?
Back in August i did try to fix my E-Brake because it doesnt stop the car like it should. (It doesnt even slow the car down). So i tried tightening the bolt on the E-Handle and it had some effect but to be safe i put it back to the way it was.
So what should i look at to eliminate the squeek?
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 11-03-2005, 12:47 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Try opening the drums and spraying brake cleaner all over. It should get rid of some dust and dirt. Catch the fluid in a pan and dispose of properly.
To adjust the brakes, this thread has some information.
To open the drums, there's two small holes on the drums that are threaded. Rlease the e-brake, and tighten two screws down in those two holes and it will force the drums off. Tighten the screws half a turn at a time alternating between the two screws. The screws are M8-1.25 or M12-1.25 IIRC.
2007 Camry 2.4L 5M
Old 11-03-2005, 01:07 AM   #3 (permalink)
Midship Captain
ModifierMR's Avatar
thanks for the info
すべての日本への私のお悔やみ。
Old 11-03-2005, 08:53 AM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
when you adjsut the rear brakes also pull the shoes away from the backing plate jsut a little witha flat bade screwdriver. When you do this take a little bit of high temp grease of lithium grease and put jsut a small amount where the shoes contact the backing plates. THis should help the squeaking also.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
