1mz oil tube leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2005, 10:14 AM   #1 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
1mz oil tube leak
so after a brisk trip to orlando (2 hour drive) i went to pull my ecu fuse because i almost ran out of gas (low fuel on a hill) and i notice a leak on top my valve cover. today i took a look at my leak to find it's comming from the spark plug tube on the #2 pistion (what would the the front of the engine closest to the radiator) well i pulled the coil pack and cleand it up, now there wasnt any oil in the tube just around it but my engine was dusty as hell and there was some crud to clean up.
now is it just the spark plug tube gaskets in the head or the seal around the tube i need to replace, and where the hell can i get the tube around the coil pack.
personaly i'm just hoping it just needed to be cleaned.
^ and leaving it that way!
Old 11-03-2005, 10:21 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
do you replace your air filter when your fuel filter clogs up?
whats an oil tube.... i must be missing something...
terrastrife is offline   Reply With Quote
Old 11-03-2005, 10:50 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
crap i mean spark plug tube, and i have a k&n so i wash mine
but ya just checked the back bank thats leaking as well so i'm going to order in a set of seals and swap them out this weekend.
anyone have any tips on chage the sparkplug tube gaskets?
also gona order me a set of NGK spark plug wires for the back bank, and some denso spark plugs.
