dumbest post ever..... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2002, 03:28 PM   #1 (permalink)
Gameroom cash: $119055
View thaharlequin's Photo Gallery
:oops:, so i want to change my air filter (92 v6le auto), the guide says to just remove the 4 clips and lift up the top half of the box. the thing is, there seems to be alot of resistence, i dont feel like bending, breaking, or snapping something unintentionaly, do i just have to force it up, or is there something else the guide didnt mention?
also, i could just use an unused circuit from the fuse box to power an amp or whatever (i'm pretty sure i dont have heated seats ), providing i put in whatever size fuse would go with the amp.
also, what would connecting my strut to my sway bar do exactly?
thaharlequin is offline   Reply With Quote
Old 11-11-2002, 03:47 PM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700165
iTrader Score: 6 reviews
View EKam's Photo Gallery
Re: dumbest post ever.....
Sometimes you'll have to be a little violent.
Someone had screwed up their car by tabbing the heated seats fuse. Don't touch it if you don't have to. You can get an external fuse box for your amp anyway.
http://www.grmotorsports.com/swaybars.html
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 11-11-2002, 03:53 PM   #3 (permalink)
so i could just buy an external box and mount it where ever, where on the (+) part of the battery, or any ciruits would it be best to run the power to the fuse box from? also, i heard that there is a certain part of the car you can ground the amp to so that you dont get any interference from everything else, any ideas where this is?
thanks by the way
Old 11-11-2002, 04:14 PM   #4 (permalink)
EKam's Avatar
From the battery is always the best.
thanks by the way
That would be any bolts that go into the body of the car (ie. exposed metal).
Old 11-11-2002, 05:58 PM   #5 (permalink)
View MTL1324's Photo Gallery
get rid of the damn air box and get an intake or at least a cone filter adapter...then you wont have to worry about hurting the box! :wink:
92 V6 Camry 3vz-fe
MTL1324 is offline   Reply With Quote
Old 11-11-2002, 07:07 PM   #6 (permalink)
View rpj1984's Photo Gallery
thanks by the way
Also make sure there is no paint under the screw...scratch off some paint if nessecary.
ryan
rpj1984 is offline   Reply With Quote
