"It appears the safety latch bracket hook bolted to the frame was set back too much to allow it to fully engage the latch release fitting bolted to the hood."
Sounds like he found the problem.
internetautomar When your hood is down is it flush with the body? If not then the posts in the frame above your lights can be adjusted up and down. That might be your problem.
Also the latch itself has 4 bolts that allow you to adjust the latch up down left and right. They torque up at 69in lbf.
 It worked fine until I fixed it!
