shaking?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2002, 07:20 AM   #1 (permalink)
View i3urtonair's Photo Gallery
shaking?!
Ok, lately when I am at a stop and in Drive (My car is automatic).. My steering wheel starts to shake and vibrate and it is driving me nuts. If I hit it, I mean absolutely slam the thing, it stops shaking for a bit but then starts up again. As soon as I am moving the shaking stops, or if I change into Neutral, the shaking and vibrating will stop as well.
Anyone have any clue as to whats causing this? And how I can fix it.
Im worried that its something with the gears since this only occurs when im in drive, and at a stop.
i3urtonair is offline   Reply With Quote
Old 11-12-2002, 11:10 AM   #2 (permalink)
View Daemon's Photo Gallery
humm just a guess but sounds like your steering box might be bad....
Daemon is offline   Reply With Quote
Old 11-12-2002, 11:17 AM   #3 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700165
iTrader Score: 6 reviews
View EKam's Photo Gallery
Check motor mounts.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 11-12-2002, 11:34 AM   #4 (permalink)
Originally Posted by ElegantKamuri
Check motor mounts.
my next guess
Old 11-12-2002, 02:04 PM   #5 (permalink)
How do I check them? Is it something I can do myself or should I go to a mechanic for that?
Old 11-12-2002, 02:27 PM   #6 (permalink)
well try this.
pop the hood and have someone start the car or jump start the car with a home made button to the starter.
see if the engine moves around, that can be one way of telling if the motor mounts are bad, also you can look under the car and look at the motor mounts and check to see if there splitting, cracked etc..
as for the steering box, a mechanic would be the best way to check that.
Old 11-12-2002, 02:33 PM   #7 (permalink)
grrroarr... ?
View jaguar's Photo Gallery
mine does it too, but only when the radiotor fan is running it, could be a malfunctioning heat sensor ?
jaguar is offline   Reply With Quote
Old 11-12-2002, 03:24 PM   #8 (permalink)
View Zeek321's Photo Gallery
my car did that, i just needed a new distributer cap. does it shake more when you turn on more electronic things like your low beams, and highs, and defrost ?
It's a midwest thaaang!!!
http://www.imagestation.com/album/?id=4291436091
Zeek321 is offline   Reply With Quote
Old 11-12-2002, 04:35 PM   #9 (permalink)
grrroarr... ?
mine does,
what or where exactly is the distributer cap ?
Old 11-18-2002, 10:37 AM   #10 (permalink)
View desmo907's Photo Gallery
Re: shaking?!
My g/fs '95 does the same thing. She took it to a shop and they said all the motor mounts and tranny mount was worn (but not broken yet), and it was ok to drive a while yet. She is waiting till i get there to fix them (not sure i can do them). They also said the "flexible" exhaust piece may need rewelding once the motor mounts are fixed.
desmo907 is offline   Reply With Quote
