Stock/Mod Questions on Rim/Tires
Hello All:
what is the weight of the 2005 stock 15x6.5 wheels? , and if and when you go higher on the rim size to 17" or 18" what is the cut off on the weight differential before you have to put on a new, better, stronger braking system? i know increases in rim/tire combined weight will also affect engine performance, as well as braking performace. i've got the handle on the tire plus sizing aspects and effects, etc... just trying to get a grip on the rim/wheel weight factor too. thanks mates.
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
