Originally Posted by Zandro
Belive me it`s normal!! If you had a little knowlege about cars
you would also know WHY it has to have a elevated rpm when cold.
Ouch that hurt!
All I know is my wifes 04 doesn't idle at 1500-1700 for 5 to 10 minutes as th OP said his does. Unless you can show me the specs for that high of idle for that long of time I am sticking by my story!
By the way the last motor I rebuilt was an Izuzu 4BD2T truck diesel which needed to be resleeved and pistons dropped into it.
The last tranny I done was a 1999 GMC 4L60E which had exploded a sunshell and was having problems with the TC unlocking then locking up but I am sure you know how to fix that problem ( You have to use a special reamer to ream the valve body and put in a sleeve kit).
Last brake job was on a C6500 rears pads/rotors and rebuilt a caliper. Not a bad job if you have the proper tools (1" impact does wonders and a 30 ton jack sure helps when the truck is fully loaded!)
Upper and lower ball joints on my Dad's Dodge Ram was the last suspension work. Scanned a 2000 S-10 the other day (secondary air problem w the air pump) There is a TSB out on that. Getting ready to do a off frame restoration off a 1989 Bronco II if I can make room in by shop. I have already rebuilt the motor and tranny a couple of years ago 2.9/A4LD.
Got a GMC 3500 HD starting to look like it will need some injection pump work pretty quick.
Luckily my boys Chevy Lumina is holding up good!!
Gary
BY the way what is your occupation?
