Handbrake adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2005, 10:50 PM   #1 (permalink)
Ferrat
Ferrat's Avatar
View Ferrat's Photo Gallery
2nd Generation Handbrake adjustment
Hey all,
Just wondering how do you do a handbrake adjustment on a gen 2. All mine does when you pull up the handbrake is act like your just touching the brakes and when you stop on even a slight hill, you need to pull them up alot.
Thanks
1989 Camry SV22 (RIP) Blown Motor
1988 Camry SV21
2001 Camry MCV20 V6 Touring
Ferrat is offline   Reply With Quote
Old 11-07-2005, 06:57 PM   #2 (permalink)
Ferrat
Ferrat's Avatar
Bump
1988 Camry SV21
Old 11-07-2005, 07:58 PM   #3 (permalink)
View Leinad's Photo Gallery
Start by checking the rear pads clerance with the drums and the pads themselves.
A hole plug in the drum gives you access to the adjuster. Adjust it to have a slight clearance.
If it doesn't work remove the back portion of the center console, the adjustment nut is there.
Good luck.
Leinad is offline   Reply With Quote
Old 12-07-2005, 10:22 AM   #4 (permalink)
View mofojordan's Photo Gallery
I have a V6 Camry, which means no drum brakes in the rear. How do I adjust my e-brake?
mofojordan is offline   Reply With Quote
Old 12-07-2005, 02:30 PM   #5 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Your care will have drum in disc brakes at the back. The inner part is where the hand bake shoes are, there a small notches in the wheel side of it, above the studs. But a flat flade screwdriver into the hole and lever up a few times, until the you feel resistrance when turning the rotor. Then back off 1 notch.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
