crank pulley
i just replaced the timing belt, water pump and seals several days ago. (BTW, great information on this forum so i was able to do this myself.) i did run into one problem when trying to remove the crank pulley - what is the thread size for the screws on the pulley?? i already had one puller but didnt have the correct size threads, so i bought a different one at sears with more sizes to no avail. in despiration i had a 5/16" tap and screws so i drilled and tapped the holes. i did all 4 as not to throw the pulley off balance. my real question is, will this cause any problems?
