Originally Posted by theamazingnate
ct-26 has an internal WG... so you should not need an external setup, 97camryman had a writeup on how to adjust the ct-26 wg setting...
http://www.toyotanation.com/forum/t126750.html
a custom manifold could be made, if desired, with a flange for an external WG... you would fabricate that to whatever size you want also
Hey by the way I redid my exhaust one day cause I was bored, Straight 3 inch dp with 2.5 inch back, 2 90 degree bends, straight thru muffler, no cat and I was boosting 10psi! I removed the wastegate actuator completely and now run the flapper wide open and it still spools up at 2500 rpms and boosts to 8psi at redline! I need to do something about it but it runs so nice that I am leaving it that way for now. It seems in OBD2 the car pulls timing on its own based on knock sensor. I am running 12.1 a/f flat across the boards tapering off to 11:1 at redline in 3rd gear on the street. No Knock, no loss in compression after thousands of boosted miles! Screw all that though I am dropping in a 3sgte now! But yeah Nathan you should add my setup to the turbo setups at the front of the sticky!
-Walbro 255lph fuel pump
-Custom -6AN fuel return line Russell and Earls fittings
-Tomei fuel rail adapter
-Aeromotive 1:1 fuel pressure regulator
-Supra 7M-GE 315cc injectors cleaned and balanced
-NGK BKR-7ES-11 spark plugs
-Toyota CT26 turbo rebuilt w/ ceramic compressor wheel
-Toyota 3SGTE turbo manifold
-Custom heat shield
-Custom waste-gate actuator for 5-6 psi
-Custom aluminum charge piping
-Front mount intercooler
-K&N air filter
-Custom 3 inch stainless steel downpipe
-Dynojet wideband O2 with laptop interface
-Custom 2.5 inch exhaust
-Magnaflow high flow cat
-Apexi SAFC2
-Autometer sport comp boost gauge
-Autometer sport comp oil pressure gauge
-Custom oil feed and drain lines
-HKS SSQV blow off valve
-ACT heavy duty clutch kit
-Oil catch can
-Tapped stock oil pan
-Mobil 1 full synthetic oil
-Unorthodox Racing underdrive pulley
-Deleted AC
-Deleted Cruise control
-Deleted balance shaft assembly
