99 Camry timing and water pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2002, 07:49 PM   #1 (permalink)
View kvkev's Photo Gallery
I'm think about changing a water pump and timing belt on a 99 Toyota Camry with 4cyl. engine with a/c. Are special tools needed for either job? Any info and or hints for either procedure would be most helpfull.
Thanks,
kvkev
kvkev is offline   Reply With Quote
Old 11-13-2002, 09:36 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
Get yourself a Haynes manual #92007 as the pictures and steps are very good in getting the job done. It will tell you what tools you will need also.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 11-13-2002, 09:59 PM   #3 (permalink)
Thanks! I'll give it a try in the morning.
kvkev
Old 11-14-2002, 07:40 AM   #4 (permalink)
View Ken4's Photo Gallery
What's the mileage on your camry?
Ken4 is offline   Reply With Quote
Old 11-14-2002, 09:35 AM   #5 (permalink)
View ca12394's Photo Gallery
You may want to check the thermostat while you are at it. After the dealer changed both the timing belt and water pump on my '95 Camry, the radiator was smoked, literally. According to the dealer, the old water pump didn't generate as high a pressure as the new one, and the increased pressure caused a crack in the radiator.
Bottom line, I have to pay for a new radiator.
Good luck!
ca12394 is offline   Reply With Quote
