Driver side headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2005, 01:10 PM   #1 (permalink)
View toyota75's Photo Gallery
HI ,
I just noticed that the driver side headlights ( high beam ) does not work. The low beam does work. On having a look from the outside the bulb filament looks intact. Any clues . This is a 01 camry.
thanks ...
toyota75 is offline   Reply With Quote
Old 11-08-2005, 01:13 PM   #2 (permalink)
View majorgercko1's Photo Gallery
does the other side's high beam work? If so, try to remove that bulb and put it on the side that does not work. If if works, then the problem is the bulb. If it does not work, you have another problem.
I dare you to compare...
majorgercko1 is offline   Reply With Quote
Old 11-08-2005, 02:59 PM   #3 (permalink)
Gameroom cash: $304255
Make sure not to touch the glass portion of either bulb with your fingers when you try switching them. The oils from your skin get on the glass and greatly shorten the life of the bulbs. If you do accidently touch the glass, then wipe it off with alcohol. It probably is the bulb.
Mike
Old 11-09-2005, 05:31 PM   #4 (permalink)
hi ,
got done with a dealer for 30$. it was the bulb !
thanks guys.
