Camry Dash Buttons - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2005, 10:28 AM   #1 (permalink)
View Sidvicious's Photo Gallery
4th Generation Camry Dash Buttons
Hey guys,
i've got a GEN4 Toy. Camry 98. At the left of the steering wheels, on the dash, it seems you have to slots that you can put button in there. It's just that i need some direction to put my fog light button and my glow gauges button.
Is there any web site with som' pics that can explained how to remove those and put in there some switches ?
Thanks
Sid.
Sidvicious is offline   Reply With Quote
Old 11-09-2005, 10:58 AM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
as for removing the knockouts you jsut need to use a very small bladed screwdriver. As for wiring fog lights up and using the holes that are left you jsut need to pick the lights and find a switch taht tiwll fit and look the way you want it to. Then jsut follow the directions for installing hte lights
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 11-09-2005, 01:03 PM   #3 (permalink)
Kosher Popes
View pope_face's Photo Gallery
I suppose if you find a switch you really like that doesn't fit you could just use the blanks and drill a couple holes to mount the switch in from behind... I think it'd be kinda cool to use those LED switches from Radio Shack or whatnot, so when your foglights are on the switch lights up.
Philly
http://freewebs.com/popeface
1997 Camry LE I4
Originally Posted by theamazingnate
a good mechanic is like a good bj giver- you always go the person that gave the service to you, and if they are not available - you just sit at home and fiddle with the problem yourself until a substandard result is met
pope_face is offline   Reply With Quote
Old 11-09-2005, 01:49 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Another way to get those covers out:
Remove the coin holder below that panel. Reach your fingers up and push the entire black panel out. On my 2000 Camry, it's not screwed in, I think it's just a couple clips. The entire black panel should come out with the dimmer knob, and the power mirror control. Then just remove the cover. Or your could just reach under and push the covers out.
2007 Camry 2.4L 5M
Old 11-10-2005, 07:42 AM   #5 (permalink)
4th Generation Thanks !
Thanks for ur info. I will do it this evening
Old 11-10-2005, 08:06 AM   #6 (permalink)
Call Me Evolution Racer
TRDCamryCL's Avatar
View TRDCamryCL's Photo Gallery
I just used the blanks and drilled a hole through it an mounted the switch for the foglights. I can take pics a lil later today...
- 5QU1NTYC4MZ - #1 BOOST WAY OR HIGHWAY Camry project is over and no more.
2004 VW GLi 1.8T w/ GT30R.
TRDCamryCL is offline   Reply With Quote
