Brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2005, 01:47 PM   #1 (permalink)
View monte17th's Photo Gallery
4th Generation Brakes
My parking brake light will not go off on my toyota 01 camry. Has this happened to anyone and what can I do to fix it.
monte17th is offline   Reply With Quote
Old 11-09-2005, 02:04 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Check the brake fluid level. If it's really low, you may have gotten air into the lines which will require bleeding if you have a different brake pedal fee.
2007 Camry 2.4L 5M
Old 11-09-2005, 02:08 PM   #3 (permalink)
Just to clearify. I'm talking about the light on the dash
Old 11-09-2005, 02:10 PM   #4 (permalink)
Yup. check the bake fluid level. The reservoir is on the driver side near the fire wall.
The most common cause for it to come on other than the parking brake engaged is low brake fluid level.
2007 Camry 2.4L 5M
Old 11-09-2005, 03:28 PM   #5 (permalink)
Gameroom cash: $304255
I think you meant to say the reservoir is on the passenger side near the fire wall.
Mike
Old 11-09-2005, 04:01 PM   #6 (permalink)
View hclee25's Photo Gallery
its on the driver side!
hclee25 is offline   Reply With Quote
Old 11-09-2005, 07:11 PM   #7 (permalink)
Flagrant Fouler
Diehonda's Avatar
View Diehonda's Photo Gallery
it is on the driver side on a Gen 4. Check it, bleed it.
Free Gen 2 Camry book for anyone coming through Louisville, KY
Diehonda is offline   Reply With Quote
Old 11-10-2005, 07:37 AM   #8 (permalink)
Thanks guys.
It was the brake fluid. Filled it and the light when off.
Old 11-10-2005, 12:20 PM   #9 (permalink)
You are correct. I don't know what my dyslexic brain was thinking when I posted that. It has been on the driver's side in every Camry I have owned. Sorry.
Mike
Old 11-10-2005, 04:42 PM   #10 (permalink)
drunken member
CCCP's Avatar
View CCCP's Photo Gallery
well if u don't have a leak, then your brakepads could be low. And replacing them will bring back fluid to the normal level, but since u added fluid wach out for it coming out when u replace brakepads
CCCP is offline   Reply With Quote
