Question: How long do your front brakes last and what kind of pads do you have? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2005, 04:25 PM   #1 (permalink)
View kramer's Photo Gallery
I'm curious as to how long the average brake pads last on your Camerys and what kind of pads did you use? I have a '95 and I just found out that I have to replace after 6K miles.
Thanks to all who answer.
- Mark
kramer is offline   Reply With Quote
Old 11-10-2005, 06:29 PM   #2 (permalink)
View Leinad's Photo Gallery
OEM 125,000 km's
A+
Leinad is offline   Reply With Quote
Old 11-10-2005, 06:39 PM   #3 (permalink)
View barthmonster's Photo Gallery
OEM and about 100,000 miles, but thats a lot of highway and not much stop-n-go.
barthmonster is offline   Reply With Quote
Old 11-10-2005, 06:45 PM   #4 (permalink)
cam2Xrunner's Avatar
- Mark
Do you have rear drum brakes? When was the last time those were adjusted/changed?
Are you using Ceramic or OE pads? If you're using cheap Organic pads then they will wear out pretty fast. I had over 40K miles of hard braking on my Akebono Ceramics and they not even halfway worn out.
Old 11-10-2005, 07:23 PM   #5 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
Not of much use to you, but my TRD pads lasted a little over a year (not sure on mileage), including autocrosses.
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 11-10-2005, 09:30 PM   #6 (permalink)
I'm not sure what type of pads were used. I had them put on at a Toyota Dealership. I assume that they used Toyota pads.
When I had the brakes done, they adjusted the rear brakes at the same time.
Thanks for the feedback. I'm going to look into the Akebono pads you mentioned.
- Mark
Old 11-10-2005, 09:52 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
It depends on how you drive, driving conditions, etc. If you race or do a lot of stop and go, you will wear them out faster than if you do a lot of highway cruising.
My OE pads on the Camry lasted about 32k miles and that car did a lot of city driving. My current pads are about 50% and they have 36k miles on them because I do a lot more highway cruising now. I have Hawk HPS metallic pads right now.
2007 Camry 2.4L 5M
Old 11-10-2005, 10:06 PM   #8 (permalink)
View driftinco's Photo Gallery
did you put the new pads on yourself?
driftinco is offline   Reply With Quote
Old 11-11-2005, 09:42 AM   #9 (permalink)
97 Camry
View Davee's Photo Gallery
97 LE Manual
I have 183,000 km or 146,000 miles & front pads are original & about half worn. You need to learn how to install or how to drive!
Davee is offline   Reply With Quote
Old 11-11-2005, 09:49 AM   #10 (permalink)
96 Camry LE 4cyl
View dcarter124's Photo Gallery
TRD pads? u might wanna consider another brand if they're lasting you one year. ofcourse unless you've put 120k+ miles on yr car
dcarter124 is offline   Reply With Quote
Old 11-11-2005, 11:56 AM   #11 (permalink)
No. They were done at a Toyota dealership.
- Mark
Old 11-11-2005, 11:57 AM   #12 (permalink)
I drive like everyone else here in Southern CA. I don't stop at the last moment when coming to stop lights or signs.
- Mark
Old 11-11-2005, 01:41 PM   #13 (permalink)
Gameroom cash: $304255
kramer,
I have a 94 Camry XLE 4 cylinder with 4 wheel discs and antilock brakes. I got around 50,000 miles on the front OEM pads. I replaced them with Raybestos full ceramic pads. It's too early to tell how many miles I will get on those. I live in surburban Chicago so my driving should be somewhat similiar to your's. The reason I brought up 4 wheel discs is that my good friend is an ex-Toyota tech and mentioned to me that Toyota vehicles with 4 wheels discs have a different proportioning valve which puts a little more pressure on the rears to stop the car; that is more pressure on the rears as opposed to vehicles with front disc/rear drum brakes. That means you will get a little longer life out of the fronts and a little shorter life out of the rears. If your car has front disc/rear drums brakes, which I think it does, my guess is you should get around 40,000 miles out of a set of front OEM pads.
That said, I have read your other post and agree with what Cyorke told you. You have a problem somewhere if you only got 6,000 miles on this last set. Either a caliper piston is sticking or one or more of the slide pins in the caliper is(are) sticking and not allowing the caliper to move (release) after braking. This will leave one or more pads always putting some pressure on the rotor. This will wear the pads quickly. In my opinoin, it's time to have a serious discussion with the dealership that installed them as to what has caused the brakes to wear out so quickly. If you don't feel you are getting a satisfactory answer from them, I would call Toyota customer service at 800-331-4331 and discuss it with them.
Good luck.
Mike
Old 11-11-2005, 01:55 PM   #14 (permalink)
drunken member
CCCP's Avatar
View CCCP's Photo Gallery
Depends on the style of driving, for me cheap pads last around 10k
CCCP is offline   Reply With Quote
Old 11-11-2005, 10:39 PM   #15 (permalink)
Originally Posted by Mike Gerber
kramer,
Good luck.
Mike
Mike,
Thanks.
I'm bringing in my car tomorrow morning for a new set of brakes. I ask to have the slide pins checked as well as any sticking.
- Mark
