Changine Timing Belt..Found Oil behind Timing Covers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2005, 07:06 PM   #1 (permalink)
View A2brb's Photo Gallery
I'm in the middle of chaning the timing belt on my 92' 5sp 2.2L Camry. After taking both of the timing covers off I noticed a little Oil sitting at the base of the Oil Pan near the crank pulley and also near the Cam Sprocket. The guy I bought the car from said it had a small oil leak but we could not figure out where it was coming from...I think it's coming from this area. There is also oil on the Chassis area in this section as well...
Could the Cam Sprocket Seal be leaking Oil? It's hard to tell.
I bought the following Parts to replace while doing the Job..
Upper and Lower Tensioners
Timing Belt...Obviously
Water Pump
What else should I change while I'm in there? Cam Seal?
Thanks for the help...
-Ben
Pics of the Job So far....
Oil Everywhere
Broken Timing Belt
92' 2.2L 16V Camry
91' Gti VR6-t
"If you aim at nothing, you will hit it every time" Zig Ziglar-
A2brb is offline   Reply With Quote
Old 11-11-2005, 07:19 PM   #2 (permalink)
View Streetglower's Photo Gallery
looks like the cam seal. reason being oil is all over the cam gear and everything else. If it was a crank seal, oil wouldnt have gotten that high up.
Streetglower is offline   Reply With Quote
Old 11-11-2005, 09:39 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
do the cam and crank seal
Old 11-12-2005, 12:10 AM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
and the oil pump seal. clean it off real good with brake cleaner when you are done and you should be good to go. for at least another 60k miles or more.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 11-12-2005, 07:46 AM   #5 (permalink)
I think your right...there was "what looked to be" fresh oil near the cam gear.
I'll git'r done...
Thanks for the help guys...
-Ben
92' 2.2L 16V Camry
91' Gti VR6-t
Old 11-12-2005, 07:53 AM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
if it like my camrys, its a little of both
Old 11-12-2005, 08:07 AM   #7 (permalink)
Any tricks/tips on changing those seals besides whats in the book/manual?
92' 2.2L 16V Camry
91' Gti VR6-t
Old 11-12-2005, 08:20 AM   #8 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
yeah, dont scratch anything and use a socket to put the new ones in, the hardest part is getting the old one out, i have found that popping the valve cover off and taking the cam saddle apart on the seal end works well because its much safer and the valve cover gasket is usually leaking anyways, put a new cover gasket on. Now the crank seal is a different animal, get a pic and very carefully pop the old one out and dont scratch the crank, use a big socket and wd40 and put the new one in flush
Old 11-12-2005, 08:32 AM   #9 (permalink)
Your the Man...Thanks for the help...
92' 2.2L 16V Camry
91' Gti VR6-t
Old 11-12-2005, 04:44 PM   #10 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
my camry used to have 2 inch of oil in timing belt cover,
replaced oil pump seal, crank shaft seal and cam seal, now it is all dry
if you are taking apart all those stuff, and parts not extremely expensive, replace all seals
and the engine should probably last a while before it leaks again.
bronzemaxell is offline   Reply With Quote
Old 11-14-2005, 07:56 AM   #11 (permalink)
Got the Seals in...The hardest one was the Cam Shaft Seal. I chose not to take the valve cover off which I'm glad I didn't...Getting it back in was a bear...there is not much clearance to tap it back in.
92' 2.2L 16V Camry
91' Gti VR6-t
Old 11-14-2005, 04:10 PM   #12 (permalink)
View barthmonster's Photo Gallery
My '94 2.2L at 200K had the same thing, it was the oil pump seal. You need that long o-ring gasket for you oil pump also. It was fairly easy. I had purchased the crank seal also meaning to replace it, it alas could not figure it out (how to do it). If course I had cleaned mine with brakeclean and had to do the timing belt twice in a row to get it correctly timed and I knew for certain it was the oil pump by looking the 2nd time.
Brad
barthmonster is offline   Reply With Quote
