Adjusting the timing after changing the timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2005, 10:58 AM   #1 (permalink)
View Mark22's Photo Gallery
I went to the dealer 3 weeks ago to change the brakes to my Camry 2001 4 cyl. They told me at 63000 miles that I should change the timing belt. I was not prepared for $500 how much they wanted for that. Last weeked I went to my mechanic and he changed it for $220. I asked him if he will adjust the timing using the strobo light and he said that is not necessary, there are some marks on the engine and they just have to be aligned. I read in the maintenance manual that you need to use the strobo light. Yesterday unfortunately I noticed that the car doesn't start like before; I have to keep the key turned on for about 4 second to start. Now I have the following questions:
1-my mechanic cut corners not using the strobo adjustment?
2-can I do it myself (I used to do for my old Ford Taurus; I had the manual with the whole procedure and the strobo light)
3-where can I get the instructions (on the net) how to make the adjustment
Thank you so much
Mark
Mark22 is offline   Reply With Quote
Old 11-12-2005, 11:15 AM   #2 (permalink)
Gameroom cash: $304255
You didn't need to change the timing belt at 63,000 miles. The change interval on the generation 4 (1997-2001) is 90,000 miles. With the generation 3's (1992-1996) it was 60,000 miles.
That said, as far as the car not starting as quick as before, take it back to your mechanic and tell him what you noticed about the lengthy starting time now required. Tell him you would feel better if he checked the timing. If he's a good guy he will check it out for you. Should take him 5 minutes.
Mike
Old 11-12-2005, 02:27 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
IF the distributor has never been moved or taken out htere really isnt a reason to check the timing with the timing light. When you do the timing belt you do not have to take the dist. out so as long as the marks are all lined up then everything should begood.
However like Mike said if it is hard to start now then take it back and jsut ask your mechanis to check it. It only takes acouple of minutes.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 11-12-2005, 03:54 PM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
No distributor in GEN 4
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 11-12-2005, 04:01 PM   #5 (permalink)
Moving Forward
I couldnt remember for sure if that was the case.
so either it is timed right or it is not. there is nothing that can be done once the belt is on it is done.
Chris
Old 11-13-2005, 10:56 AM   #6 (permalink)
Mad Aussie Toy Owner
toyboyracer's Avatar
View toyboyracer's Photo Gallery
Australia Even I got it right !
Most likely cause is that the mechanic screwd up and skipped a tooth
when putting the belt on..
Easy enuff to do and easier to correct....
Adjust the timing !
I just did (for the 1st time) a tb in my 1990 Camry and the first time
I oopsied so I took it off and put it right... Could've adjusted the distributor
BUT that's not the RIGHT THING TO DO.
No big deal but if I can get it right so should your mechanic !
Some people are like slinkies,,,,Not really good for anything,,,,
But they still bring a smile to your face when you push them down a flight of stairs
Unfortunately evreyone has an opinion [q] ME [/q]
"The Thunder From Down Under"
http://www.camcrew.com.au
toyboyracer is offline   Reply With Quote
Old 11-13-2005, 07:54 PM   #7 (permalink)
But how to adjust the ignitation timing if it doesn't have a distributor? Or he has to reinstall the belt, meaning about 3 hours of work. I am sure that he's not goint to be happy with that.
Old 11-13-2005, 08:12 PM   #8 (permalink)
View Ken4's Photo Gallery
'01 camry gen4.5 uses twin coil packs and is distributorless. There is no way to adjust timing. As long as the alignment marks are correct at TDC (0 deg on crank pulley), there is no other adjustment to make. Taking 4 secs longer to start doesnt mean it is the fault of the timing belt job. How's the power? Is it the same? Is there pinging? If you still feel uncomfortable, pay your mechanic to open up the timing belt cover again to check alignment, if it wasnt done right, then he has to foot the bill.
Ken4 is offline   Reply With Quote
Old 11-14-2005, 05:38 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You can't.
The ignition timing is controled by the ECU and determined by sensors (cam position and crank position).
Well if he installed the belt wrong, its his fault. Should of checked the alignment before bolting everything back up.
"Skoolin' the unlearned!"
Old 11-14-2005, 07:19 PM   #10 (permalink)
Regarding the power, it seems a bit lazier than before; pinging, no thank God. Could be from bad gasoline?
Old 11-15-2005, 07:35 AM   #11 (permalink)
If you have lost power, it could be the timing belt job wasnt aligned perfect. It may not ping bcos the ECU may automatically retard timing.
Old 12-17-2005, 11:18 AM   #12 (permalink)
I went back to the mechanic and explained the problem. He first changed an engine mount (I think is called like that-a rubber thing) that solved most of the rough shaking. After that he checked again the timing belt, he said that even installed another new one to make sure that it wasn't the belt the culprit and he said that everything it is ok but he can't explain the problem that still exists, delay in starting. I just checked today the fuel consumption (I haven't done this in a year) and is not good, 16m/1 gal (60% city+40% highway). Should I go to the dealer to have the codes checked? Thank you.
Old 12-17-2005, 02:59 PM   #13 (permalink)
You can go to Autozone, if you have them in your area, and they will check the codes for you for free. Was the check engine light ever on? You didn't mention this in your other posts.
Mike
Old 12-17-2005, 03:37 PM   #14 (permalink)
No, the check engine was never on.
Old 12-17-2005, 05:48 PM   #15 (permalink)
View sixsick6's Photo Gallery
You need to check to see if your timing belt is lined up on the top and bottom. Just because there are marks doesn't mean that a "mechanic" lined them up correctly, especially if the car is running like crap now. If you want to do it correctly, you have to use a timing light to check your work. I don't care how good you are, just because you removed everything and think you replaced it in the same order, a final check with a timing light takes less than 5 minutes and completes the job, and should be done.
Use this thread (which I have no idea why it hasn't been stickied yet?) to see what you're up against:http://www.toyotanation.com/forum/t109966.html
Via con Dios mi amigo!!!
sixsick6 is offline   Reply With Quote
