Questions for guys who custom painted their interiors... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2005, 06:37 PM   #1 (permalink)
Hi.
View mystickid's Photo Gallery
Cool Questions for guys who custom painted their interiors...
I want to custom paint all my interior vinyl and I know that masking will be a lot harder for me because for one thing, I basically have to mask a whole lot of my interior and don't want to risk messing up and having paint on places its not supposed to be, because I've messed up before with a masking job. Man that was a long run-on sentence.
Anyways, for you guys who have custom painted your own interiors, I just have one question and concern. If one doesn’t disassemble and later re-assemble all the screws, clips and parts properly, then you get all sorts of rattles and junk that are so darn annoying to me. so I'd like to seek some wisdom for experience(s).
are There Any disassembling guides that can walk me through disassembling my interior parts. I already know how to do the door panels, cup holders w/ storage console box, & glove compartment box.
My main concern is the big huge front dash across the front of the interior. If I take it off will the SRS bag blow open, what about the steering wheel airbag while taking the steering wheel off? Also the side and rear pillars and bottom feet pillars, I don't know.
I really need a guide and some help. .
mystickid is offline   Reply With Quote
Old 11-13-2005, 06:54 PM   #2 (permalink)
Kosher Popes
View pope_face's Photo Gallery
First off, what year? I think that's key. Other than that... I think the Haynes Manual should show you where the clips are and all... I've got a copy of the service manual that's floating around here, so I'll take a peek on that, but I think it's mainly a couple screws on the bottom and sides of the dash, and I believe the whole thing will come off directly, including the SRS. But... I don't have much experiance in this. Maybe a search will help?
Philly
http://freewebs.com/popeface
1997 Camry LE I4
Originally Posted by theamazingnate
a good mechanic is like a good bj giver- you always go the person that gave the service to you, and if they are not available - you just sit at home and fiddle with the problem yourself until a substandard result is met
pope_face is offline   Reply With Quote
Old 11-14-2005, 06:55 AM   #3 (permalink)
Hi.
Yeah i got a 1998 LE 2.2L I4 camry.
Old 11-14-2005, 03:14 PM   #4 (permalink)
Kosher Popes
I took a look at the manual and you don't have to worry about the SRS exploding on you... but there are a few things that you've gotta watch out for. It says that you have to wait at least 90 seconds after putting the ignition in the LOCK position and unhooking the battery before attempting any work on the airbags... if you try it within 90 seconds you can set the airbag off. The other thing that you might want to do is remove the airbag sensors from the car before playing with the dash. It's probably not necessary, but just as a precaution. Other than that... just be careful with it. I don't remember exactly the process, but basically you have to remove the front door sill trim pieces, the steering wheel and column, the center console, glovebox, radio, all that crap, and then you can unbolt the dashboard itself. IIRC, it's just screws holding the actual dash panel onto the car. It sounds like it'll take a bit of time, and I've never done it before myself, but that's what I got from the manual. I'll take a look at it later after my afternoon classes and try to post up the relevant pages...
Philly
1997 Camry LE I4
Old 11-14-2005, 06:38 PM   #5 (permalink)
Hi.
Thanx a bunch pope_face.
Old 11-14-2005, 09:41 PM   #6 (permalink)
Upgrade Addict
View [TüsK]'s Photo Gallery
I took everything off but the dash. Just label everything and keep it orgainized and you should be golden. Take your time too.
[TüsK] is offline   Reply With Quote
Old 11-14-2005, 09:57 PM   #7 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
The whole dash?
I just painted the plastic interrior panels, the air vents, handles, trim etc... thats insane man, good luck
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 11-14-2005, 10:06 PM   #8 (permalink)
Xzbit702's Avatar
View Xzbit702's Photo Gallery
U dont have to take out the Dash just make sure you mask everything like your seats,the Doors,and the windsheild.The most importiant info i can give is to be very patient and use very light coats and TAKE YOUR TIME BE PATAINT.Here is a pic of my interior take a look http://www.cardomain.com/ride/2167345/1 Just take your time you will be fine.
Xzbit702 is offline   Reply With Quote
Old 11-15-2005, 06:56 AM   #9 (permalink)
Hi.
What type of paint did you use xzbit?
Old 11-15-2005, 08:23 AM   #10 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
I would take it out. its sooo much easier to work on stuff if you do it that way. It takes time, but well worth it
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 11-15-2005, 08:31 AM   #11 (permalink)
View Grayguy's Photo Gallery
I did my dash in the car, and I must say, that it would be so much easier/ better to make it out. I was not happy with my results at all. When Spring rolls around I'm gonna get a different dash outta the yard and do it out side the car, then swap it for mine.
Grayguy is offline   Reply With Quote
Old 11-15-2005, 08:34 AM   #12 (permalink)
Also, I'd like to add that the duplicolor everybody said I should use was crap. I did the dash with that, and it sucks. Then I did one door panel with the expensive stuff (like $9 a can) and that stuff was even worth in my opinion. What I finally ended up using is actually meant for putting on bumpers, but it looks way better, and seems to be holding up way better then the other two kinds I tried. I don't remeber the brand, but I can check and post when I get home tonight.
Old 11-15-2005, 09:25 AM   #13 (permalink)
View GStizzle's Photo Gallery
Originally Posted by BrianOwens
The whole dash?
What kind of paint did you use? How long did it take?
GStizzle is offline   Reply With Quote
Old 11-15-2005, 10:35 AM   #14 (permalink)
Art In Motion
Mayne Event's Avatar
View Mayne Event's Photo Gallery
yea...I have been wanting to do this but dont want some nasty spray paint lookn on my dask. what kinda paint should be used? like brand and location where to get this shit?
There are no stupid questions, Just stupid people.
http://www.cardomain.com/id/badblood
Mayne Event is offline   Reply With Quote
Old 11-15-2005, 10:50 AM   #15 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I've painted quite a few interiors and most of the times I've used Krylon Fusion plastic paint. At times I have also used ordinary spray and it held up good for me. Before I paint I usually use some warm water with some soap powder or detergent to get off any grease, dirt, or armorall etc. Then I wet sand it a bit. That's my method of doing and it hasn't failed me since. Also take your time, and don't rush.
http://www.xclusive.bz
