Just wanted to give you my impressions of the Tokico struts I installed this weekend. Got started at 10:00am and me and my Toyota bud David were finished @ 2:30pm. Not too shabby. I used the stock springs. The 1st thing I noticed was the stability on the road. The new struts track the road much better. When I cross a rail road the rocking side to side and bounce is gone. In a turn, the Camry tracks flatter.... if not flat. I added the White line sway bar a while back. It did not have the "wham" effect I was looking for at the time.. but it DID help the body roll. NOW, with the new struts and the sway bar... NOW, I am getting what I was looking for! I checked the ride heighth, and it was unchanged. So, my impressions are a very strong POSITIVE impression of the Tokico struts. Ride comfort, road noise and performance were all addressed in a positive manner. Next on the list, is a replacement Walbro fuel pump. I was able to locate the proper "kit" the TCA324.
That is the one. Once I install. then I will add the ZEX 82021 kit. Whilst we were under the hood, we checked and I DO HAVE a return fuel system. So, this fuel pump will assist on the fuel starvation issues and the N2O delivery...
Anyway, I wanted to share my thoughts and imprressions!
SCDTRD
1994 Toyota Camry V6 XLE I LOVE it!
And the journey continues........
Yes, I reused them. I have 55k miles on them, and they were in ok shape. The BOOTS on the other hand were dry rotted and in bad shape. Also, the rubber coil spring thing for the bottom of the coils were in need of replacement. So, my suggestion to you is....
Reuse the tops, but replace all other rubber items, they are cheap and just good to do while you have it apart.
Other than that, not a problem. take your time and align the arrows on the tops to the strut.
SCDTRD
Ok, this may seem like a wierd question but please bear with me
Is a strut/spring replacement something that a highschool mechanics class could maybe do?
I am curious b/c i'm pretty sure i'm on all origional struts and springs at 152,000 miles
Hmmm... my shocks are kinda... well, shot. They squeak and thud and definately don't absorb the impacts any more... however, I do have a quick, if not possibly strange, question on shocks/springs. I need to change out the shocks for sure. In fact, I could probably use a new suspension system. I do want to eliminate the body roll for the most part, but I don't want to drop the car. I'd like to keep it stock height. I'm really agressive when it comes to driving, and I do a lot of "urban offroading", namely speedbumps, potholes, and the occasional curb. The Cam has a tendancy to bottom out on some speedbumps at low speeds. It could just be my un-absorbing shocks, but I'm considering a skidplate eventually. Anyways, what I want to know is what kind of shocks or shock/spring combos can I get that will give me a firm ride but won't drop the car? And stabilizers, what kind should I get, how hard are they to install, and how much would a whole setup cost, roughly?
Philly
EDIT: Ok, I just realized that this is a Gen 3 thread and I've got a Gen 4... but I'll assume that at least the shock question would still be applicable... anyone?
a good mechanic is like a good bj giver- you always go the person that gave the service to you, and if they are not available - you just sit at home and fiddle with the problem yourself until a substandard result is met
Philly
Your only bet for some good springs for your model car would be some Eibach or some H&R. They WILL drop your car but only about an inch, HARDLY noticable. The H&R's will drop it a little more closer to an inch and a half but they are about 220$ the Eibachs are closer to 250$ but will only drop it about an inch. Heres a link
are you using tokico inserts right? Is it difficult to remove the old cartridge?
No, I did not get the inserts, I replaced the whole strut. I checked, and my Camry did NOT have inserts.
BTW, I checked the stock strut when I got home and it was bad! I mean, I pushed down on the rod and it went down with almost NO force, and CREPT back.
SCDTRD
tokico is the way to go no doubt... I love mine so far. H&R springs are very nice as well, the drop isnt terribly noticeable and there is still about a 3 finger gap but the tradeoff of form for function makes them well worth it
My '94 got new KYB GR-2's all the way around and it RAISED the car a tad. Also the handling is very nice, better cornering than new. I put new KYB mounts in back, and Gabriel mounts up front (cheaper). I re-used the lower spring rubber, but it was in bad shape, if its cheap I'd replace it. Also new front strut bearings, also KYB
Just order STANDARD HEIGHT Springs from any of the after market manufactures !
Yes they sell LOWERED Springs but do stock height springs as well...
And just by getting new springs and TOUGHER shocks body roll will be almost minimal compared to the stock setup !
__________________ Some peopleare likeslinkies,,,,Notreally good for anything,,,, But they stillbring a smile to your face when you push them down a flight of stairs Unfortunatelyevreyonehas an opinion [q] ME [/q]
"The Thunder From Down Under" http://www.camcrew.com.au
Just order STANDARD HEIGHT Springs from any of the after market manufactures!
Well, you know, that makes perfect sense... I found a place (kinda) locally that sells Tokico Blues and Eibach Pro kits, so I'll call them tommorow and ask about pricing for the whole deal. The thing is, they also sell Tokico kits, with struts and springs. Would there be any benefit to either combo? I've gotta look into getting the whole wheel area redone. It probably doesn't need it, but I'm at 147,XXX kM and would feel better having everything replaced. Along with a new set of wheels... but yes, Tokico/Eibach or entire Tokico kit?
