3vzfe valve adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2005, 07:33 PM   #1 (permalink)
OMNI's Avatar
View OMNI's Photo Gallery
hello all, I am new here. I have done some work on my 93 camry v6 with the 3vzfe. I did the head gaskets as well as all seals. I had a shop put in new valve seals and adjust the valves, I doubt they did either. the car runs good but is noisy and somewhat of a hard start. I think the timing is off and it needs a valve adjustment. what tools do I need to purchase to be able to adjust the valve clearance? is there a online manual for this? I think the guys at the shop that did the valve seals mixed up the shims and caused me a headache. thanks for your help.
OMNI is offline   Reply With Quote
Old 11-14-2005, 08:49 PM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
A better reference for you would be a haynes or chiltons manual, $20 at any of the big auto stores around your area. As for everything else, um... I have absolutey no idea.
BTW.... Welcome to the Nation!!
BlueFusion6851 is offline   Reply With Quote
Old 11-14-2005, 09:33 PM   #3 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285280
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
http://www.toyotanation.com/forum/t62501.html
your welcome
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 11-14-2005, 10:01 PM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
adjsuting valves on most Toyota engines is not as easy as jsut pulling hte valve cover and uncrewing or screwing the adjauting screw. They use shims taht have to be removed and replaced to get the adjustment right. And there are tons of possible shims. If you get the manual opened up you can search it and youwills ee how it is done and all of the shims that could or could not be needed.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 11-15-2005, 05:31 PM   #5 (permalink)
OMNI's Avatar
thanks
Originally Posted by Knailgun
it already tried that link. it refers to the v6 as 1mzfe, which is in the sienna/avalon. I have the 3vzfe. I have taken the shims out before. I was referring to the tool used to compress the valve so the shim could be taken out for measurement. there are like 4 diff ones and some do and do not work on this particular engine. I wouldn't mind pulling the cams either if need be, I might as well do the timing belt while in there.
Old 11-15-2005, 06:29 PM   #6 (permalink)
engineer in training
Gameroom cash: $145055
If you didnt use a service bolt to hold the exhaust cam sub gears in place they are out of alignment and not pre-meshing the scissor gears properly, this causes what sounds like valve noise.
Old 11-19-2005, 04:16 AM   #7 (permalink)
OMNI's Avatar
nope
I had home depot quality service bolts, I still have them too. it just has lots of click clacks. I have to go back in to check the cam bearing clearance and check for excessive wear. so nobody here does a valve adjustment on this car? I found the tool, I was just curious as to where would a good place to buy it. plus there are a few of them for diff applications in the toyota line.
