dead RPM needle :( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2005, 08:46 PM   #1 (permalink)
View dstlaurent's Photo Gallery
3rd Generation dead RPM needle :(
Hi everyone ... i have two problems ... (appear after my glow gauge installation). The first is:
1- For find a good power source i have test all the wire with a voltmeter. When i have tested a "green" wire, a little blue spark was appear and a little "click" in the dash. And now, all the needle work fine, but the RPM doesn't work All the fuse it's ok, where is the problem ????
2- My AIR BAG lamp is ON ... (i know i have only to reset it ...)
thanks
David
NOTICE: ANY TIME, XCUSE MY ENGLISH QUALITY ...
Camry Gen 3 1993
LE 3VZ-FE (V6)
236 000 km
dstlaurent is offline   Reply With Quote
Old 11-14-2005, 09:11 PM   #2 (permalink)
[K][a][M][r][Y]
View KamryStylez's Photo Gallery
check to see if the guage is popping out making your needle impossible to move...plus i hope you didnt take out your needles when you install it or put on the guages roughly where the needle might be damage. If those dont work get a new cluster.
95 Camry v6 LE
Cardomain: http://www.cardomain.com/id/kkkamryyy
KamryStylez is offline   Reply With Quote
Old 11-14-2005, 09:21 PM   #3 (permalink)
oh i have test, and i put the needle at 8000 rpm and it return to zero ... i didnt take out the needles ... if i change only the RPM part, this is OK ?
Camry Gen 3 1993
LE 3VZ-FE (V6)
236 000 km
Old 11-15-2005, 08:57 AM   #4 (permalink)
[K][a][M][r][Y]
forgot to tell you if you make sure the plugs back there are securely plugged in
95 Camry v6 LE
Old 11-15-2005, 10:22 AM   #5 (permalink)
ok, i will test it PM thanks alot
Camry Gen 3 1993
LE 3VZ-FE (V6)
236 000 km
Old 11-15-2005, 11:38 AM   #6 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
check carefully the circular part of the gauge in the center, the part that will be near the black plastic cirlce of the needle, it could be making contact there. I dremeled the edge of the clear plastic of the gauge in that circle (NOT the glow part of the gauge!!) to ensure that there was no contact. My speedo still catches a snag once in a while, its been a year, but I hope this helps.
Damon
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 11-15-2005, 01:51 PM   #7 (permalink)
you're right a little part of the glow make a contact with the needle ... i will re-install it more carefully
thanks!!!!!!
Camry Gen 3 1993
LE 3VZ-FE (V6)
236 000 km
