Can't pass smog...suggestions anyone??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2005, 10:43 PM   #1 (permalink)
View rdayton_67's Photo Gallery
Question Can't pass smog...suggestions anyone???
I need help! Just got an "88 Camry that was grandpa's car and can't get it to pass smog. Gave it a tune up, new catalytic converter, new plugs and wires, new ERG valve and still can't get it to pass. Anybody have any suggestions as what to do next?
Thanks!
rdayton_67 is offline   Reply With Quote
Old 11-14-2005, 10:48 PM   #2 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
is the check engine light on? Try some of thet addictive that is suppose to guarrantee to make you pass the smog check.
V6LE_CAMRY is offline   Reply With Quote
Old 11-14-2005, 10:50 PM   #3 (permalink)
check engine light isn't on. they say we are very close to passing, but still off enough to fail. tried three times. where would i get the additive? do you remember what its called?
Old 11-14-2005, 10:56 PM   #4 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
http://www.autobarn.net/ch05063.html
kenny1773 is offline   Reply With Quote
Old 11-14-2005, 10:58 PM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
fuel injector cleaning?
seafoam?
and how hot did you run the car before the tests? makes a huge difference, and the amount that they run your car isn't enough to warm up your car sufficiently
HaHa
Old 11-14-2005, 11:08 PM   #6 (permalink)
took the car out and ran it up and down the highway about 110mph for fifteen minutes, then took it through town for another 10 winding it up pretty good. the first smog tech told him no additives, but he had already tried one.
Old 11-15-2005, 10:13 AM   #7 (permalink)
View Reppinshadyvill's Photo Gallery
Change the PCV Valve
Reppinshadyvill is offline   Reply With Quote
Old 11-15-2005, 10:17 AM   #8 (permalink)
View dirtdiggler's Photo Gallery
what part is failing ? nox ? egr port of entry from air intake might be clog. my previa did the same thing.
dirt diggler
91 Previa w/275k
07 Mercedes C230 Sport
07 FJ Cruiser
92 Lexus SC400 w/84k
97 Prelude w/86k
dirtdiggler is offline   Reply With Quote
Old 11-15-2005, 12:18 PM   #9 (permalink)
View ruoknow's Photo Gallery
Maybe the design standards for car emission in 1988 is different from nowerdays.
ruoknow is offline   Reply With Quote
Old 11-15-2005, 04:49 PM   #10 (permalink)
View fox_prime's Photo Gallery
noob question
this may be a noob question but...
what do tune-ups do? cuz i have no idea about them. my smog check is due on 12/13/05...and my check engine light is still on.
it came on after i installed the Ripp headers. btw, i smell a lot of fumes under the car (near the cat converter) and a lot out of the exhaust whenever i warm-up or come to a stop. the only thing that may be wrong is an air leak near the catalytic converter (at the end of the downpipe to the beginning of the cat, i see water dripping in between what holds those two together)...could that be why?
help me please!
fox_prime is offline   Reply With Quote
Old 11-15-2005, 04:58 PM   #11 (permalink)
View Gary_602Z's Photo Gallery
Thanks!
How is your O2 sensor?
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 11-15-2005, 06:29 PM   #12 (permalink)
9thGen Corolla
karma's Avatar
View karma's Photo Gallery
The worst thing you can do is just go around putting crap in your engine and replacing working parts.
First things first
Post your smog readout
We can all look at it and see what is too high and give you a suggestion. If we cannot come to a conclusion I would just pay the money and take it to a shop that will run a smog diagnostic on it and they will pin point the problem and you can repair it. See the problem is that without the readouts we do not know what is happening in your engine and as complicated as an engine is it is near impossible to diagnose with no data
Boosted 10 psi Camry Coupe R.I.P 8/17/05
New Project: 9th Gen Corolla, MA71 Supra, Gen1 Solara SLE
karma is offline   Reply With Quote
Old 11-15-2005, 06:51 PM   #13 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
karma's right post which categories u failed so we can help u out
johnnyzee is offline   Reply With Quote
Old 11-24-2005, 10:01 AM   #14 (permalink)
DONE! And running well!
View rojo412's Photo Gallery
I am having the damn near exact same problem. My 88 is failing the CO and Hydrocarbons, but not by much. I heard the O2 and cat may be the culprits.
The failed readings are as follows on my particular car:
CO @ 2500 RPM - 2.47% (1.2% passes)
HC @ Idle - 269 ppm (220 passes)
CO @ Idle - 2.07% (1.2% passes)
The passing grade was the HC @ 2500, which were 182 ppm.
The first time I went, I don't think I had the car warm enough, but the readings changed for the worse in some cases. Mostly minor, but the CO got worse at idle.
Any of the pros have an idea as to what may be the problem?
Also, here in Ohio, if you can prove you spent $300 to fix the problem, even if you don't pass, they'll waiver the car. I don't know if other states do that, but it might be worth checking out.
I freakin' love my goofy wagon!
rojo412 is offline   Reply With Quote
Old 11-24-2005, 02:31 PM   #15 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
USA on sunday at 10:00 tune to am 710
Thanks!
I only no about the newer camrys but at 10:00 on sunday tune on to am 710 and call the car doctor he should now what to do
BlackCamSe is online now   Reply With Quote
