Changed the Timing...Now Engine won't turn over... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2005, 12:16 AM   #1 (permalink)
View A2brb's Photo Gallery
3rd Generation Changed the Timing...Now Engine won't turn over...
Question..Just put a timing belt on the Camry. Checked the timing 3 times and everything was good to go...All marks lined up perfectly after 720* rotation... Hooked up a good battery and tried to turn it over and got absolutely nothing. It won't even turn over...
The Dome light comes on like it suppose to and the headlights turn on/off. With the Key in the Car, the door dings when I have it open...The Dash lights do not come on at all when I turn the key over.
I checked back over the wiring in the engine bay. I also checked the fuses..OK...I didn't take any wiring apart so I have no clue what this could be.
What do you guys think?
Thanks,
-Ben
92' 2.2L 16V Camry
91' Gti VR6-t
"If you aim at nothing, you will hit it every time" Zig Ziglar-
A2brb is offline   Reply With Quote
Old 11-15-2005, 12:23 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Popped the alternator fuse in underhood fusebox most likely. Did you reconnect the ground by the passenger side motor mount at the valve cover?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 11-15-2005, 07:59 AM   #3 (permalink)
I checked the gound and it's attached. The fuse is ok. I'll check back over them again.
Would a bad ground cause this????
92' 2.2L 16V Camry
91' Gti VR6-t
Old 11-15-2005, 12:04 PM   #4 (permalink)
Ok...Got it to turn over...The prevous owner busted one of the big fuses in the box and tried to jump it by bending over the two brass tongs. Jumped those and it turns over now...However it still does not start...
It's trying to start but won't. Smells like it's flooded now. I tested the fuel pump by the Hanes Manual (Jumped the two Pins in the Diagnostic Plug In) and it's buzzin so that is not it. Played with the Spark Plug wires a little...
It's bumpin while turning it over but just won't fire up...I'm getting a headache...
Suggestions???
92' 2.2L 16V Camry
91' Gti VR6-t
Old 11-15-2005, 02:00 PM   #5 (permalink)
Gameroom cash: $304255
It does now sound like a flooded engine. Try holding the excelerator pedal down to the floor as you crank it. That is the recommended procedure for starting a flooded engine; either fuel injected or old carburated engines. If that doesn't get it started, you might try taking the plugs out and blow them dry with some compressed air. They may be completely soaked with fuel and will not fire.
Mike
Old 11-15-2005, 02:09 PM   #6 (permalink)
Moving Forward
View Cyorke's Photo Gallery
^^^ everything he said is right on. If you dont have compressed air you can also try using brake cleaner to clean them off and let the dry for a minute or so since it evaporates so quickly.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 11-15-2005, 02:16 PM   #7 (permalink)
I do have compressed air so I'll try that...
Didn't know you could hold down the accelerator. Thought that would flood it more.
I'll let you know what happens...
92' 2.2L 16V Camry
91' Gti VR6-t
Old 11-15-2005, 02:49 PM   #8 (permalink)
Moving Forward
yeah jsut hold the pedal to the floor til it starts then go from there. It will probably run like crap for the first few seconds and it iwll still be ahrd to start jsut hold it to the floor and keep cranking once it tries to kick over.
Chris
Old 11-15-2005, 03:35 PM   #9 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
please put a real fuse in.
chances are you left the plug unplugged from the distributor or something stupid like that...
otherwise, i can only think that you maye have some plug wires crossed, or that you did the timing wrong.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 11-15-2005, 03:42 PM   #10 (permalink)
I wish it was that easy...I have tripple checked everything. As for the Fuse, I will try to find the proper one. It's one of those big square ones. I shoot a pic of what the Previous Owner Rigged up...Previous Owners Frustrate me...If you going to do something do it right...
Stay tuned and I will let you know what happens...
92' 2.2L 16V Camry
91' Gti VR6-t
Old 11-15-2005, 05:24 PM   #11 (permalink)
OMNI's Avatar
View OMNI's Photo Gallery
I did that once and it would attempt to run. turns out the spark plug wires were not connected in firing order.
OMNI is offline   Reply With Quote
Old 11-16-2005, 11:01 AM   #12 (permalink)
Update:
Changed the Spark Plugs, Wires, Cap, Rotor. The Car started but runs like Poo.
Rechecked the timing and everything is on Target.
Checked for Spark and it seems to have a good blue spark.
Runs really rough and won't stay started. Guess I can't really complain since I only paid $200 for the Car.
I'll keep at it...
92' 2.2L 16V Camry
91' Gti VR6-t
Old 11-16-2005, 11:03 AM   #13 (permalink)
Moving Forward
have you tried cleaning eh throttle body and all associated parts there. Just another idea as far as rough idle an things like that
Chris
Old 11-16-2005, 11:30 AM   #14 (permalink)
I will try that...
I did take most of the grounds off the car and clean every one just for peace of mind. Cleaned and sanded every mating surface with a dremal tool....
I almost feel like it's an injector issue.
92' 2.2L 16V Camry
91' Gti VR6-t
Old 11-16-2005, 12:02 PM   #15 (permalink)
I'm a Mac
zoni's Avatar
then throw some injector cleaner in the fuel if thats how you feel.
Dave Zoni
