All,
New to the group and happy with my choice on all accounts - car & forum.
As of a week ago, I now own a 95 Cam LE V6 Auto, 152K. After the one week shake down we have the following:
1) Rack is leaking from the bellows left side. I guess it could be either seal but the bellows on the left lets it drip 1 qt in 400miles.
How hard is it to replace?
How far can I lower the engine cradle before I wreck stuff?
Are there any special tools required?
Should I check anything else before I yank the R/P?
2) There is cam speed tick from the front bank (just one of the 24). Engine noise quickly hides it at RPM, I can only hear it at idle. Hopefully some fluid/filter changes will make it happy? Idle is smooth and it pulls good to 6K.
Need attention as time permits:
*) Driver side door lock, only unlocks, won't lock the car. It won't turn to the left (NBD).
*) Does it have the dealer installed door remotes switch, if so - get a remote...
*) Tuner needs to go, Supertuner III MP3 coming soon. This looks almost more painful than the rack!
Looking forward to any info on the rack replacement -
Thanks,
/ra
Yes - The V8 is parked....
All 350HP Ford 351C 4Spd, Posi
