starting concern - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2005, 08:58 PM   #1 (permalink)
fungke's Avatar
View fungke's Photo Gallery
Gen5 starting concern
got off from work today...it was about 7 degrees celcius and it has been raining all day. got into the car and started it...seemed to not want to start. i think i held it there for a good 10 seconds. i let go of it...then start again and it worked fine.
anything i should be worried about here..i mean..it's not that cold out there..and if this is happening now....i am afraid of what will happen when winter comes.
any ideas as to what i can check?
03 Camry SE
fungke is offline   Reply With Quote
Old 11-15-2005, 09:26 PM   #2 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
Switch to Synthetic Oil? it'll help with cold starts? i dunno. Remember to turn off all electrical devices before starting including : headlights, anything in cigarette lighter plug, A/C, radio, etc.
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 11-16-2005, 07:06 AM   #3 (permalink)
View Gary_602Z's Photo Gallery
Kind of confusing. Are you saying the first time you tried it that it would crank but just not fire? Or would it not even crank over on the first try. Two different symptoms. Each would probably take a different route to fix.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 11-16-2005, 08:14 AM   #4 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
you prolly need a new battery, my 03 camry is starting to take longer to start on cold days here in NE as well. Im gonna need a new battery this winter i know it, escpecially because of my sound system.
Id think about getting a battery soon, If its not the battery you can always just return it and get your money back.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 11-16-2005, 09:28 AM   #5 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Like Gary said would the car not crank or did it crank and jsut not start.
Cold weather is a bitch on cars. Especially when starting.
Maybe someone else can chime in on this also dot do the Gen4's still ahv the cold start injector in the intake plenum. Maybe the cold start system is in need af some repairs. I know on the Gen3's we used to have to work on them some starting this time of the year.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 11-16-2005, 09:51 AM   #6 (permalink)
fungke's Avatar
sorry about any confusion...
the first time..it cranked but did not fire
the second time it worked like normal.
the thing is it just happened once....but i am afraid since the winter is coming along.
i guess i should get my battery tested...any other ideas?
03 Camry SE
Old 11-16-2005, 09:55 AM   #7 (permalink)
Moving Forward
If it cranked with no problem it is not the battery more than likely. Like I said in an earlier post the older ones ahd a cold start injector that was hooked up to a temp sensor for wehn you start it in the cold. I can not rememerb if the Gen4 has this or not since I quit working for Toyota right after the Gen 4 came out. You may want to check into this to see if it may be your problem.
Chris
Old 11-16-2005, 10:24 AM   #8 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
I notice you're in Canada. Do they change the fuel blend for winter up there like they do in the US to reduce iceing and parafin that could clog injectors?
I assume they do and where you got gas may still have some of the summer blend of fuel.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 11-16-2005, 02:29 PM   #9 (permalink)
Got to believe that since it cranked okay it could be the cold start system like cyorke said or possibly something to do with the dampness?
Gary
Old 11-16-2005, 08:47 PM   #10 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
do they sell engine block heaters for Camry's?
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 11-16-2005, 10:10 PM   #11 (permalink)
Moving Forward
You can buy aftermarket heaters for jsut about any car cant you. Try your local parts stores and see what you can come up with.
Chris
Old 11-16-2005, 11:57 PM   #12 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
my old car the mazda had similar problem, tune up fixed it, you up for one yet?
johnnyzee is offline   Reply With Quote
Old 11-16-2005, 11:59 PM   #13 (permalink)
fungke's Avatar
i just had one about a month ago...
03 Camry SE
