NEED HELP ASAP - Will these fit? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2005, 12:55 PM   #1 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
3rd Generation NEED HELP ASAP - Will these fit?
Hi All,
I have very good deal on a set of wheels but need to hear from you: Will they Fit the 95 Camry LE V6?
They are: 17' chrome factory Lexus wheels and tires off a 2001 GS300 (5 LUG). Tires are Toyo Proxes 215/50/R17...
Edit: It looks like the wheels came from GS400\Gs430 and are 17X8 - with 38/45mm offset. But I could be in error. Not sure "how accurate" the data is....
http://www.wheelsandcaps.com/catalog...S&_MODEL=GS400
What is your take on this? My springs are stock - all is stock with reference to struts and ride height.
Didn't mean to be so needy but - I need to give this chap an answer before he sells them to someone else.
Thanks in Advance!
/Randy
73sport is offline   Reply With Quote
Old 11-17-2005, 02:28 PM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
bolt pattern, rim size is all good. Only thing is the offset. I have no idea about the GS300, but the IS300 uses a +50 offset, so you'll need spacers.
Silver Streak is offline   Reply With Quote
Old 11-17-2005, 02:32 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Beat me to it. As long as the offset is close to what you ahve now then you should be ok. Factory offset is +38 I think so you dont want to stray from taht number very far. The offset should be stamped on the wheel somewhere or the guy you are wanting to buy from should be able to tell you waht it is.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 11-17-2005, 05:13 PM   #4 (permalink)
View iganpo's Photo Gallery
I had 215/50/17 on my Gen3 wagon. With stock suspension the right height was pretty tall. It looked silly but wasn't unsafe. Sorry, I don't know about the offset.
iganpo is offline   Reply With Quote
Old 11-17-2005, 06:19 PM   #5 (permalink)
V8'sRGone
73sport's Avatar
I stuck my hand in....
Thanks for the info:
I went out and stuck my hand in between the tire and strut. The front has lots of room (stock wheels). The rear is to tight for my fat fingers. So it looks like any offset needs to be Negative or it will rub on the strut. Mind you the factory wheels are 15" X 6" and these are 17" X 8" (I think).
HOW MUCH OF A SPACER is OK? Are we just talking about 10 - 20 mm or more!?
I did find this which helps in the tire department; it lets you compare different sizes. Pretty handy.
www.1010tires.com/Tiresizecalculator.asp
It shows a 3% increase in diameter.
I think the best test will be the fit test. Can't say i want to do this in someones driveway though.....
Thanks again,
/ra
Old 11-17-2005, 07:05 PM   #6 (permalink)
View thoughthard's Photo Gallery
According to http://www.capitalwheels.com/store/c...s.php?pageid=8, they fit. Offset is still in question though.
thoughthard is offline   Reply With Quote
Old 11-17-2005, 07:14 PM   #7 (permalink)
Offset answer, but I cannot confirm it...
http://au.lexusownersclub.com/forums...showtopic=1122
Old 11-17-2005, 10:51 PM   #8 (permalink)
V8'sRGone
73sport's Avatar
3rd Generation Thanks - this helps
Very helpful - I have several saying they should fit and the owner says they are +42mm.
They should be these if all things are true....
http://www.capitalwheels.com/newsite...74147x-lrg.gif
CW-74147
Lexus GS400
1998-2002
17x8
5x4.5
hey - thanks for the foot work...
/ra
Old 11-17-2005, 10:56 PM   #9 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
my enkeis on my gen 3 are 42 mm offset, they fit flawlessly, no rubbing and im lowered. hope that helps
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 11-18-2005, 11:07 PM   #10 (permalink)
V8'sRGone
73sport's Avatar
USA What a bummer.....
This is just an FYI:
I tried the wheels on tonight and no dice.... They hit the rear struts. Spacer is required.
It was hard to walk away and leave them shiny nice wheels there with the new skins on them....
Recap: 17" X 8" 42, 215/50R17 Lexus wheels do not fit the rear of a 95 Camry
Regards,
/ra
Old 12-03-2005, 09:19 PM   #11 (permalink)
Rated-R's Avatar
View Rated-R's Photo Gallery
Lexus GS300 rims
I will confirm that the offset on a stock 17x8 GS400 rim is a +50 offset. I will also confirm that the offset of a stock 17x7.5 IS300 rims also has a +50 offset. These rims will not fit on the Camry unfortunately as you have confirmed. Btw, may i ask how much the seller was asking for that wheel and tire combo?
Rated-R is offline   Reply With Quote
Old 12-03-2005, 09:22 PM   #12 (permalink)
Rated-R's Avatar
i don't think those rims are OEM rims dude. If they're infact +42 offset, they must be replica's or the seller may have misinformed you on the offsets. You can check behind the rim and see the stamped specs of the rim. It should say TOYOTA / 17x8 / +50 offset.
Old 12-04-2005, 01:41 AM   #13 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
im likin these!!!
http://www.tirerack.com/servlet/Call...&showRear=null
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 12-04-2005, 01:39 PM   #14 (permalink)
V8'sRGone
73sport's Avatar
They are gone now =(
Well....
I called our local Lexus dealer and told them what they were. he said +42.
I was looking at them in a poorly lit garage and did not look for a stamp. The LEXUS sitting next to them had never been in the rain ever. That ride was flawless and so were the wheels. They wer VERY NICE with no rash and NEW 95% pirrellie tires. I did fit them for and aft. $600 bucks was the accepting offer, he had them listed for $1000 originally, no takers and needed some cash. I am 95% certain they were the OEM wheels and you may be correct about the +50, I had no way to measure them.
My question is this: With an 8" Rim, What is the max backspace that will still fit the aft strut?
I found a place on the web that sells both OEM and aftermarket, both listed them as +42. So I am not sure what to think other then it doesn't matter now, someone else has them.
Here is what i ended up with, 17 X 7, +38 TSW Valcano's mainly caas I hate the mutli lug patterns and wanted something thats easy to clean, no rivets or sharp edges....
Regards,
/ra
Old 12-05-2005, 12:22 AM   #15 (permalink)
Rated-R's Avatar
Originally Posted by 73sport
Well....
Regards,
/ra
For $600 thats a pretty decent price. Although i think you can get cheaper if you really look around. I have OEM 17" Chrome GS400 rims and they are 17x8 with a +50 offset on my GS300. I don't think the dealer knows what he's talking about unless Lexus changed offsets on GS400 rims after a certain year. Who knows, i might be wrong but im pretty sure OEM offset is +50. Like the TSW's though!
