winterizing camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2002, 02:49 PM   #1 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
winterizing camry
i would like to know what i should do to it for the winter?
so far it has less then a 1000 miles from the last oil change
taken out the battery
cleaned and waxed
have car cover
gas stabilizer
pretty much this is the jist of it: i cannot jack it up to take off the rims because of my side skirts, and the jack that i have. I don't think it will hurt the wheels to let them sit for the winter, they did last winter and nothing happened.
but should i do anything to the engine? like put some oil in each cylinder or anything like that?
also where is the best place to store my battery?
thanks
alex is offline   Reply With Quote
Old 11-20-2002, 03:47 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
engine, run the car and spray fogging oil in the intake until the car dies, then leave her be
battery; store it somewhere in the house, don't forget to put it on a couple 2x4's or else it will go dead
i would try and jack up the car, just to releave all the pressure on the springs, and on the tires, you should be able to get the little cissor jack from your trunk somewhere under the car, even if its far from the edge, and put her up on jackstands/logs/cinderblocks
before restarting her in the spring i would drain the oil and put it back through the engine just to try and lubrify a little before you crank like crazy to get rid of the fogging oil
-Nick
Nick is offline   Reply With Quote
Old 11-20-2002, 05:33 PM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Here's a basic article with some pointers.
http://www.cdnrods.com/Articles/WinterStorage.asp
You really should try and get the wheels off and car lifted.
Phi is offline   Reply With Quote
Old 11-20-2002, 08:31 PM   #4 (permalink)
View Zeek321's Photo Gallery
Wow, i just took off my rims. looks like i have a lot more to do...
It's a midwest thaaang!!!
http://www.imagestation.com/album/?id=4291436091
Zeek321 is offline   Reply With Quote
Old 11-21-2002, 12:53 AM   #5 (permalink)
DJModifyd
alex's Avatar
so what is the best way to jack up the car?
i can't fit the sissor jack underneith
also, i've heard people go both ways about jacking it up....is it REALLY neccisary?
also, what is the 'fogging" oil called
Old 11-21-2002, 03:09 AM   #6 (permalink)
rayray's Avatar
View rayray's Photo Gallery
if you can't get the jack under the car:
a) buy a crazy expensive flat jack like the one from ultimategarage.com
b) buy some cheap ramps so your car has enough clearance to fit the jacks or stands.
c) drive up some 2 x 4's ???
-rayray
rayray is offline   Reply With Quote
Old 11-21-2002, 11:15 AM   #7 (permalink)
DJModifyd
alex's Avatar
-rayray
i can fit the jack under the car, but the side skirt hides the pinch weld so i have nothing to put the car onto
and also i can't afford jack stands...........so it looks like its staying on the ground.
i'm buying some fogging oil today........so that part will be finished.
Old 11-21-2002, 10:05 PM   #8 (permalink)
Nick's Avatar
go to a construction yard and acquire a few errand cinder blocks,
or logs.. make sure they're cut straight, and are pretty wide, i wouldn't use anything smaller than 10 inches in diameter
-Nick
