Limited Slip Differential aka LSD Pro's and Con's?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2005, 09:10 PM   #1 (permalink)
Gameroom cash: $368676
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
A topic I seen that hasn't really been covered for the Camry's are the LSD's.
It sparked my curiousity when I heard it adjusts the power between the wheel whether it be cornering or a straight road. It also puts the power to both wheels (on a straight road) and allows the car to take off without and slipping (hence lsd).
Now, what would the cons be?
I was told a theory of there would be too much grip that you would actually lose acceleration by this test: Put your hand on the table and push forward sliding your hand lightly. Now pretend you have an LSD, push your hand more than firmly on the table and push forward, which will take off faster? I don't know if this is good to go by because I would think all the power goes to the wheels since it would have the right amount of traction.
Well, if anyone can post any arguments, pro's, con's etc., I can further decide (and as a community) if it's really a worth while mod.
http://www.quaifeamerica.com/
RichieRichJP is online now   Reply With Quote
Old 11-20-2005, 01:31 AM   #2 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
my friends all got LSD on der cars.. it's perfect for track but gets really annoying when your parking your car. it shakes like crazy when your steering wheel is turned all the way to the side. i guess this would be a Con. and for pro i heard no complaints on ek9 eg6 or dc2's stock lsd or from tuners
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 11-20-2005, 01:49 AM   #3 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
I know the guys looking for big power all put in LSD's. IIRC thats one of the reasons UFOZ is planning to replace his tranny.
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 11-20-2005, 02:19 AM   #4 (permalink)
Gameroom cash: $199835
View swegyptian's Photo Gallery
LSD is needed for traction, but pretty annoying for daily drivers, depending on which LSD you get. Most OEM LSDs are not bad, but my Cusco is pretty annoying with all the shakes and shimmies.
www.swegyptian.com
swegyptian is offline   Reply With Quote
Old 11-20-2005, 04:25 AM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
no no no.
NO CONS AT ALL with a torsen LSD.
terrastrife is offline   Reply With Quote
Old 11-20-2005, 04:53 AM   #6 (permalink)
Working hard?
View noofa's Photo Gallery
best burnouts ever
what is better - wheelspin on one wheel
Both wheels having traction for the whole take off and gear changes?
Rep'in Team Hamster In OZ
Need power? Get an Ebay Intake mod!!!
***MOD: Signature violation. Size is too big. Keep it under 500x150 pixels.***
noofa is offline   Reply With Quote
Old 11-20-2005, 11:43 AM   #7 (permalink)
Kosher Popes
View pope_face's Photo Gallery
Yeah, I think it might be a good thing to have. I've never used it, and I would be wary of the apparent excessive vibration, but I don't see the connection to the palm and the table. If you're talking about your palm being the tire, you're trying to push the table away from you, which is good to have more friction. However... if there's more friction inside the differential for any reason, then you could start wearing stuff out.
Just my $0.02.
Philly
http://freewebs.com/popeface
1997 Camry LE I4
Originally Posted by theamazingnate
a good mechanic is like a good bj giver- you always go the person that gave the service to you, and if they are not available - you just sit at home and fiddle with the problem yourself until a substandard result is met
pope_face is offline   Reply With Quote
Old 11-20-2005, 12:22 PM   #8 (permalink)
Thanks for the replies. Yeah, my car is a daily driver and still willbe after it's turboed for a long time...so since this limits the slippage, will that mean any power lost from the wheels would be gained back?
Old 11-20-2005, 05:49 PM   #9 (permalink)
and then some.
going from no lsd to a good oen is like changing ya whole suspension set up. the car totally changes.
go go torsen lsd !
