Change brake pads questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2005, 07:38 PM   #1 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Gen5 Change brake pads questions
It is time for a brake pad change. I have a 04 Le w/ rear durms I have 95K miles on it now. What do I need to change the front pads? I read the How to in the FAQs, but it doesn't mention replacing the shims, is this needed? Does it matter what kind of anti-squeak I use? What are the torque specs for the bolts holding the caliper on? Do you guys think it will be time to replace the rear pads too?
I can take pictures when I do this in december if anyone wants.
drunken_panda is offline   Reply With Quote
Old 11-20-2005, 08:33 PM   #2 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
You can reuse the shims that are on the factory pads. I would recommend using Toyota pads cause otherwise they tend to squeak a little. I believe you will just need a 14mm wrench and a caliper compressor. The rears shouldn't need to be replaced yet due to the fact that they only do about half as much braking as the fronts. But to be sure you can pull off the drums and check them. You probably should pull the drums and clean up the rear brakes anyhow.
BadChicken is offline   Reply With Quote
Old 11-20-2005, 09:04 PM   #3 (permalink)
View Gary_602Z's Photo Gallery
If your rotors are wore or grooved any I would have them turned also.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 11-20-2005, 10:16 PM   #4 (permalink)
drunken member
CCCP's Avatar
View CCCP's Photo Gallery
^^^ I never used exact torque specs on those bolts that hold caliper in place, just make sure u apply even force on both bolts that hold caliper, i belive it will make an even wear on the brake pad.
And yes, reusing old shims is fine.
I don't know why everybody recomends to use anti-squeak, i never used it on my old cars and camry, no squeaks even on old rotors.
CCCP is offline   Reply With Quote
