another engine light
So for the past 2 months I have been dumping crap loads of money into fixing the car, ranging from CEL to changing the rack and pinion.
At my last visit the dealership diagonsised 3 CEL, one for EGR system, P0335 Crankshaft position sensor circuit "A" malfuntion, and P0340 Camshaft position sensor circuit malfuntion.
They said that there is a chance that fixing the EGR system CEL will clear the other 2 CEL out. But jsut as we all know, it didn't.... that didn't surprise me at all.
So now, I'm left with the P0335 and P0340 CEL code. THis is the description the dealership gave me.
P0335 crankshaft position sensor circuit "A" malfuntion.
P0343 camshaft position sensor circuit malfuntion
perform diagnosis back probe the ECU. intermittant signal from Cam position and crank position sensor. take closer look at in ECU connector E8 got full of oil in it. check at camshaft position sensor leak oil. that why went throught wire insulator than to ECU. suggest replace cam sensor first.
so then i called another dealership to see if this situation is possible, just as I thought they'll say... "it is possible". and i checked with the parts department to see how much the sensors are, apparently they don't have "camshaft position sensor" listed in their computer.
Now my question is, how can I confirm which part is the culprit? Because I do not want to replace both parts when I only have to replace one.
And also, has anyone else came acros this problem before? And what damage would it do, if i don't proceed to fixing this?
Thanks
1994 Camry LE V6
Tokico blues + Vogtland / Depo headlamps / Clear bumper light / Silverstar / AEM CAI / Tenzo R Formula 10 + Kumho 215/50/17
