First time poster. Shift lock porblem..need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2005, 04:16 PM   #1 (permalink)
View savvycamry's Photo Gallery
New person here. Glad I found this forum. its very informative. Hope someone can help me on this problem.
I have a 1996 Camry auto. The other day as i was in park I started it as normal but the shifter would not come out of Park. I used the shift lock overirde system to allow me to shift out of park so I was able to get home. I realized while driving my rear lights were not working also.
So far what I did is i checked the fuses and realized my #19 fuse was blown. It is a 15amp so i replaced it. When i replaced it the shifter worked the first time but as the 2nd time the fuse blew again and i ened up with the same problem. tried it a 3rd time and again it blew.
I'm guessing I have a problem in the wiring or it must be electrical. Driving without brake lights is dangerous and know I need to take it in.
Was hoping someone might know something before I bring it in that I can try or if they have an idea what might be the problem.
If I put in a 20amp fuse, could that help or might that cause more damage?
Any help is appreciated.
Thanks in advance.
savvycamry is offline   Reply With Quote
Old 11-21-2005, 04:39 PM   #2 (permalink)
View .tony. .riot.'s Photo Gallery
I had a similar problem, but my car didn't blow out any fuses. It was the stop switch. You can get one from around $45 from Toyota.
I didn't buy a new one, my mechanic just took the stop switch out, cleaned it pretty good and it was working fine again.
.tony. .riot. is offline   Reply With Quote
Old 11-21-2005, 04:55 PM   #3 (permalink)
View qeg84dox's Photo Gallery
Try a 30 amp! Just kidding. Sounds like you have a wiring problem. This could be difficult to diagnose. I hate to say it but you should probably take it in.(Dealer)
qeg84dox is offline   Reply With Quote
Old 11-21-2005, 05:31 PM   #4 (permalink)
View Gary_602Z's Photo Gallery
Check your brake light bulbs and the sockets you may have one shorting out.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 11-21-2005, 05:38 PM   #5 (permalink)
Gary
Thanks for the advice Gary. How would you check a socket is difective?
Old 11-21-2005, 06:17 PM   #6 (permalink)
Look for mainly corrosion but also check that the bottom of the bulbs are making contact. You can also check for power and ground with a test light. Check a bulb by holding it up so you can see the filament and the flick it with your finger and see if you can see a broken filament move around.
Gary
Old 11-21-2005, 06:36 PM   #7 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Also check to make sure you ahve not spilled anything on the shift lock.
I was looking in my owners manual and the #19 fuse controls the brake lights, shift lock, and cruise control.
Makes it seem likely the brake switch has gone out and is shorted maybe.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
