Rims and tires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2005, 05:42 PM   #1 (permalink)
View Reppinshadyvill's Photo Gallery
4th Generation Rims and tires
OK MY NEW RIMS ARRIVED... but here's the problem. Now I wanted to put 225/45/18's all around but someone at the rim shop told me that they would probably rub in the back. (The back of my car sit a lil bit lower than the front) Soooooo I got 225/40's for the rear (shouldn't really be able to tell the difference)
Here are some problems I foresee:
1- The back will probably rub when I have two occupants back there.
2- There may be some handling problems due to the different aspect tires.
3- The rim shop gave me three tires that can only go on the right side of the car LMAO (idiots i will take care of that tomorrow)
I need suggestions, will I be ok as is? All you guys who have 18's let me know what aspect you are running with rubs or w/o. Also the reason I wanted 45's is because I live in NY (nuff said)
Reppinshadyvill is offline   Reply With Quote
Old 11-21-2005, 06:13 PM   #2 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
if it rubs get ur rear fender ROLLED not cut. do relief cuts on it then bend inward. i got 19's and they dont rub at all......
lucanhookup is offline   Reply With Quote
Old 11-21-2005, 09:11 PM   #3 (permalink)
Art In Motion
Mayne Event's Avatar
View Mayne Event's Photo Gallery
check my profile. I have put 20's and am getting them (once I pay them off) and they dont rub. I have 18's now and have it lowered. Theres NEVER been a rub. My 20's have 35 series tires on them. 18's with 40 series wont even come close to rubbing.
There are no stupid questions, Just stupid people.
http://www.cardomain.com/id/badblood
Mayne Event is offline   Reply With Quote
Old 11-21-2005, 09:14 PM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
if it rubs youre wheels are the wrong offset
get your guuards CUT not rolled. rolling is cheaper but it also make syour guards loose structural integrity.
terrastrife is offline   Reply With Quote
Old 11-21-2005, 09:19 PM   #5 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
spacer will work for the back..
skewe is offline   Reply With Quote
Old 11-21-2005, 09:46 PM   #6 (permalink)
and rub hte guards even more?
hehe this is why i always say 205 for race tyres and 215 sectrion for street tyres.
you dont really need anymore width then that for a normal camry.
Old 11-21-2005, 10:06 PM   #7 (permalink)
word to ur mother
if ur talking about cutting that little lip of the fender then it will make the fender weak......
Old 11-21-2005, 10:14 PM   #8 (permalink)
cutting the lip still leaves the 90 degree bend in place.. which is what gives it strength
rolling it flat makes it flat... no support.
Old 11-21-2005, 10:44 PM   #9 (permalink)
word to ur mother
it also depends how much u cut too. if u cut the whole thing ur screwed....lol
Old 11-21-2005, 10:49 PM   #10 (permalink)
nothing ebay universla flares cant fix :P
and if you need to cut more then you really got the wrong wheels.
Old 11-21-2005, 11:13 PM   #11 (permalink)
Australian TN'er
View Phat Devil's Photo Gallery
4th Generation
I just got my 18x8s in the gen 4. I got 235/40/18s on them.
They needed 5mm spacers to stop them hitting the struts
And my car has superlows. It rubs the lip on bumps and if there are people in the back so you will need to the the rear guards rolled. 35mm drop from standard (1.5in)
Handling of the car is a lot better as there is now more rubber on the road.
And my speedo is off by 1.1%. So not much.
hope this helps
Look at my thread if you want to have a look at how it sits
Finally got my 18x8s on my Gen4!!!
Phat devil
Phat Devil is offline   Reply With Quote
Old 11-21-2005, 11:35 PM   #12 (permalink)
hope this helps
Phat devil
more rubber on the road isnt bette rhandling. its usually wose actaully car tracks more (follows the cracks in the road) aquaplanes more (oh shit) and at slower speeds, you have less grip.
the handling came from the reduction in sidewall movement and tyre block squirm.
Old 11-22-2005, 10:08 AM   #13 (permalink)
ok just to clarify its not that the tire is rubbing on the fender. It is rubbing on the plate where the spring sits when I drive over bumpy roads the 45 aspect tires scrape so im going to change them up today and see what happens.
Old 11-22-2005, 03:54 PM   #14 (permalink)
skewe's Avatar
To be technically precise and in accordance to terrastrife rules.. we must be extremely precise when explaining something.
i.e. more rubber is better for handling, but not according to terrastrife. terrastrife's theory. aquaplane.
Apparently, one needs to understand that when we mention more rubber better, that is during regular conditions, without ice, snow, oil, volcano eruptions, etc..
I would love to see a F1 or an indy car (based on terrastrife explaination) go down the speed way with maybe 3" wide tires that makes contact to the ground.
Old 11-22-2005, 04:35 PM   #15 (permalink)
Art In Motion
I dont understand this^^^ how can your rim rub on the underside of the plate that holds the springs? Between the plate and rotors is solid, there should be no give there so if the rims fit inside the plate there there shouldent be a problem. I just dont get how all of you can be having this problem with 18's and im puttin 20's on my ride with almost the same size tire. Maybe becasue I drive a coupe and its alot lighter so it doesent rub as much...i dunno?
