front and rear struts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2005, 11:47 PM   #1 (permalink)
View Jchan's Photo Gallery
Gen5 front and rear struts
how many miles do you start having problems with the suspension. when to replace them
02 SE V6
Make some cash!!
www.agloco.com/r/BBFW0796
Jchan is offline   Reply With Quote
Old 11-23-2005, 01:20 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
you replace them when you have problems (or ideally at the end of their rated service life).
terrastrife is offline   Reply With Quote
Old 11-23-2005, 09:38 AM   #3 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Look for Oil leaks
Two things:
1) Pull the strut boots up and look for oil residue around the shaft. If its leaking it will soon stop dampening.
2) Got to each corner of the car, give it a good solid push downward with all your weight. Compression dampening (down) and rebound dampening (up) should be the same on all four corners of the car.
If one corner bounces a couple of times and the others don't, its time for replacement.
Good Luck.
/randy
73sport is offline   Reply With Quote
