trying to figure out if my car is actually overheating
I've got a '95 camry 5sfe, and for several months my temperature gauge has been telling me that I have a problem with overheating. It's seemed that the problem is that the fans don't turn on until the temp gauge is pretty close to the red...I've tried replacing the thermostat and the coolant temperature switch, but the new ones seemed to work worse than the old ones. On my way from NC to FL my gauge sat at about 2/3 to 3/4 of the max pretty much the whole way, even after unplugging the temp switch so that the fans ran constantly. The sender for the gauge is only about a year old, but I'm beginning to think it may be faulty...Is there a good way to tell if my car is actually overheating or not? The coolant overflow tank isn't spilling over even when the needle is just below the red, and I'm not seeing any steam...is it possible that the sender for the gauge has broken somehow that makes it show a higher temperature...the last time it broke it just didn't work period.
thanks
