safc ?
ok so as most of you know now i bought a supercharger with out the computer or anything, so i was going to drive it with a safc.
in searching i found alot of dead links, so any exact model of the safc? safc or emanage? and which could i use to have it trigger the waste gate on it to open up when changing gears.
also whats the stock injector flow rate, and which 2jz injector was it the ge or the gte?
from reading things zoni wrote i wount need to rebuild the block really for 9psi.
also any sugestions on a easy to install FPR,
any other tips or advice?
^ and leaving it that way!
