2vz-fe base timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2005, 04:07 PM   #1 (permalink)
View sea1mdk's Photo Gallery
2vz-fe base timing
89 camry 2vz-fe; rebuilt engine and fired it up ran smooth and quiet. hit operating tempature and idle speed came down. started running a litle rougher, but i couldn't get the timing any closer than 15 btdc. had jumper wire in place. seems as computer has more control than i do.
sea1mdk is offline   Reply With Quote
Old 11-25-2005, 09:01 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Base timing is 10degrees BTDC.
Computer does control the timing, but with the jumper in place, it allows you to set it via the distributor. TB all correct?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
